I just picked up my 2020 silverado 2500HD High Country.
Does anyone know the part numbers for these parts.  Dealership was no help. I have them in chrome and looking to get them in black and then paint the grille, valance, and door handles summit white.
Black plastic tow mirror covers
Black plastic hood vent
Black bottom window trim.
Any helps appreciated.
Thanks
Dealership didn't help because they know you aren't going to buy them from them....I don't blame them....
Edited by newdude
I buy all my parts from them.  For the the last 3 silverados I had I've gone to them.  So to say that without knowing where I buy my parts from is just dumb.
Try asking before you make a stupid comment next time.
  • Sad 1
84468908 - textured black like the rest of the mirror
84468910 - textured black like the rest of the mirror
84520315 - WT textured black
Need to know build date of truck due to 2 designs.
Build date is 1/2020.
Thanks for part numbers.
I've bought 3 silverados from them and all my parts.  I went out of state to get this truck but I bought other parts from my local dealership like always.(for this truck)
Thanks for the part numbers and yes I talked to the same guy I've known there for years in the parts department.  Good guy.  He was able to order me a few other parts I needed but wasn't able to find the part numbers for the parts I listed.
  • 10 months later...
59 minutes ago, TetonA said:
@newdude for the rear belt moldings in black would a truck with a build date of July 2020 change those part numbers you listed?
Yep the 1st/2nd design changeover is Sept 1st 2019 so anything after that date is 2nd design.
I've got a 2020 High Country and it seems like you also need part 84692173 (Applique Panel) because the rear window molding (part 84831871) doesn't include the 1-2" chrome elbow piece towards the very rear of the window (see image).
Is that right? I have the rear window moldings but they are definitely missing that final small corner piece.
@newdude sorry to tag you again here -- but figured you may know the answer to this :)
Edited by TetonA
FYI - if you've owned Chevy trucks in the past or have over a certain mileage you can join Chevy truck legends and get a code for 20% off all accessories you purchase thru the dealer.  I do this all the time, it's saved me alot of cash since I bought my truck
84692173 and 84692172.  Whole vertical molding.
I still had them from the OP lol but never added them here.
Edited by newdude
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
