I just picked up my 2020 silverado 2500HD High Country.
Does anyone know the part numbers for these parts.  Dealership was no help. I have them in chrome and looking to get them in black and then paint the grille, valance, and door handles summit white.
Black plastic tow mirror covers
Black plastic hood vent
Black bottom window trim.
Any helps appreciated.
Thanks
Dealership didn't help because they know you aren't going to buy them from them....I don't blame them....
Edited by newdude
I buy all my parts from them.  For the the last 3 silverados I had I've gone to them.  So to say that without knowing where I buy my parts from is just dumb.
Try asking before you make a stupid comment next time.
  • Sad 1
84468908 - textured black like the rest of the mirror
84468910 - textured black like the rest of the mirror
84520315 - WT textured black
Need to know build date of truck due to 2 designs.
Build date is 1/2020.
Thanks for part numbers.
I've bought 3 silverados from them and all my parts.  I went out of state to get this truck but I bought other parts from my local dealership like always.(for this truck)
Thanks for the part numbers and yes I talked to the same guy I've known there for years in the parts department.  Good guy.  He was able to order me a few other parts I needed but wasn't able to find the part numbers for the parts I listed.
  • 10 months later...
59 minutes ago, TetonA said:
@newdude for the rear belt moldings in black would a truck with a build date of July 2020 change those part numbers you listed?
Yep the 1st/2nd design changeover is Sept 1st 2019 so anything after that date is 2nd design.
I've got a 2020 High Country and it seems like you also need part 84692173 (Applique Panel) because the rear window molding (part 84831871) doesn't include the 1-2" chrome elbow piece towards the very rear of the window (see image).
Is that right? I have the rear window moldings but they are definitely missing that final small corner piece.
@newdude sorry to tag you again here -- but figured you may know the answer to this :)
Edited by TetonA
FYI - if you've owned Chevy trucks in the past or have over a certain mileage you can join Chevy truck legends and get a code for 20% off all accessories you purchase thru the dealer.  I do this all the time, it's saved me alot of cash since I bought my truck
84692173 and 84692172.  Whole vertical molding.
I still had them from the OP lol but never added them here.
Edited by newdude
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 1,224 Guests (See full list)
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses more gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
