I just bought a 2019 with bench/center console. I have the power on the back but none inside the top console. My 2015 had usb - this one does not. Has anyone ran power to their center console so you can charge a phone in it vs having a cord hang from the dash. Maybe I am missing something.
Edited by Tnbeast
I did this.  I relocated the stock USB charging plate into the bench seat middle compartment.The shop I used then routed the power to it.  From there I ordered the identical USB charging plate and placed it in the original portion on the dash with no power hooked up to it.  Using it as a dummy cover.
There's a thread on here somewhere where he tapped into a line somewhere to add a USB inside the top.
So - here's a question.  Is the wiring harness there already?  I have a custom, and do not have the power in the back seat by the vents, but, would love a USB for charging only for my minions back there.
There is no power under the seat in a custom model. I am waiting on a plug that another member on here sold me to hook up power in the console
Apologies for reviving an old thread. I have out a full console into my 2019 Custom. I'm looking to find this harness. Do you happen to know the part # for it?
  • 8 months later...
  • 10 months later...
    250.3k
    No1UKnow
    No1UKnow
  • Who's Online   5 Members, 1 Anonymous, 1,150 Guests (See full list)
    • My take: I don't think seeing up to 200k on the odometer of any of these engines/trucks (2014-to present) is surprising. (Excluding the known DEFECTS, specifically, the 6.2 main/connecting rod bearing issues, the defective lifters, alternatively parts that a recall was issued for - I think there were three.)   250K is my line in the sand, anything over that is 'surprising', but not limited to the engine making it that far but including the truck surrounding it too. (We've talked about this in other posts, why I think the engine isn't the deciding factor for ultimate mileage.)
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
