LED tail lights
Has anyone ever wondered why they put LED tail lights on the custom and not the LT?  I don’t know if they have them on the RST and higher trims, but I definitely don’t have it on my LT.
I think this was done on the 2020 models. My 2020 custom came with led bed lighting, led tail lights and center arm rest storage. All of which I believe was not on the 2019 customs
2019 and up new body style Customs have LED tails (but ironically halogen headlights).
LT gets LED headlights but incandescent taillights.
If you want LED front and back, RST & up.
If I had to choose one, I’d take the LED headlights over the taillights for practical and appearance reasons. The LED taillights look so similar to the incandescent ones it’s almost pointless.
Uh yeah, I'll take a number 5, hold the mayo, the pickles and I'll have a liter of cola.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 830 Guests (See full list)
