Differential not aligned
Is it normal for the rear of a 2020 trail boss one tire passenger side is sticking out more than the driver side
I just checked my neighbors trail boss and it’s the same as mine
If anyone with a trail boss could check would appreciate the help
Gotta photo of your truck?
This is passenger side
This is driver side
Does the box look like it’s lined up with the cab?
Yes
At this point I would measure brake rotors to the frame. Seems to me the truck wouldn't drive straight if the axel was not aligned correctly with the frame. Maybe get someone to follow you and see if the truck is dog tracking. I think it's far more likely the box/cab are off center than the axel being off by an inch.
Jay
It matches the rest of the back end of the silverado - ugly and misaligned.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
