This thread will have all my mods for my truck will be alot of post over the next few weeks
SOME POST WILL BE MODIFIED TO ADD THE FINISHED PICTURES
PLEASE PM ME ANY QUESTIONS ABOUT ANY OF THESE POST
Pictured next to my 15 1500 with 2 in lift
Sent from my Moto Z (2) using Tapatalk
Edited by mkeddie
First mod
nfab running boards
First holes drilled
Back rack on
Edited by mkeddie
Torn apart....
lots of parts and pieces to get behind the dash to run wiring
Edited by mkeddie
What are the holes for?
Fire radio
Red CONSTANT power (unused sunroof 40amp fuse pulled)
Yellow IGN power (would assume 50mp but not sure )
passenger side fuse panel
Edited by mkeddie
Got the dash back together and pulled the back seat...
Wasn't easy to figure out but now it will be a 5 min removal
lots of interest on how to pull the seat so there is a post below with a writeup on how to remove
Now to figure out how to cram 4 more electronics boxes in there 2cd199e1e8ecb4e75465372d6d4cb786.jpg60e897b9ac2ede61afea6275b2447870.jpg
Edited by mkeddie
The grille came out for siren install and grille mod/replace( retrofitting camera into other grille)
Center Chevrolet part Currently out to paint 480a935dfae8aa0b5605ec849918c3f8.jpg5b97c28b470d654e164f06b099a3a358.jpg6acf306138e114717abf8e1598fb6b32.jpgf8e07ba7e5b935c21aee14271f7c5cbd.jpg79358e27546330a8186280db90ef17c8.jpg
ab380635596c2d0e79bbf1457c095883.jpg1de923d2ab52ad90712dd8c22ceb49f9.jpg92ef254a9f6ec232c56e4fe97e3a3f81.jpg
Will you be ale to modify the front end to make it easier on the eyes like your 15?
Yes it will look more like this e0b1c5e51b1ba872e9180add94b01006.jpg608a7e2a875a80f8111000b503ff09f2.jpg
On 5/6/2020 at 6:24 PM, mkeddie said:
Torn apart....
lots of parts and pieces to get behind the dash to run wiring IMG_20200506_182159053.jpg
How did you route the wires out of the cab to the light bar that’s on the back rack?
That will probably be posted tomorrow
Been busting thru these projects taking pictures as I go
Here is how I routed all my wiring
They are all weather tight electric connectors
37dd88f8da3e42aca436632209659992.jpgb3a9e613c6369d240e8cd12ea21ec1f4.jpgb31fa063667c92e0bbc0df7d357ebc86.jpg315005296bccec34f8bb33ea0d04b707.jpg024b43330998b771674baf33fecfdbfa.jpg48c2ebbef4d37fbb4f77816c220186f4.jpg
    Smitty462
    Smitty462
  • Who's Online   5 Members, 0 Anonymous, 703 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
