Fixing the Chevy Shakes!
Mobil 1 Synthetic LV ATF HP 124715
My 2016 Silverado with 82,000 miles has had the shaking issue for a couple years or the 30,000-40,000 miles. This issue for me occurs around the 70 mph-80 mph range. The center console would shake so bad that I would have to dial back the speed to below 72 mph.
Measures I have taken to resolve the “Chevy Shakes” None of these worked.
1)    Re-balance old tires Free
2)    Purchased new tires $1,200
3)    Alignment $84
4)    Re-balance Drive Line $160
5)    Road-master Shock Absorbed $500 (This did help some of the shake mostly the handling and ride)
Fixed the issue!!
1)    Transmission flush with the correct transmission fluid $200 (Which does not come in transmission from factory) Mobil 1 Synthetic LV ATF HP 124715
I was able to flush the transmission myself. There are guides online that can walk you through it if you have the time and skill.
Here is a Link:
4L60E Transmission Flush Guide
https://www.newgmparts.com/4l60e-transmission-flush-guide
Took me 4 hours and I was able to flush transmission and change motor oil as well. The dealership wanted $140 for diagnostic and $750 for flush. Since the transmission was my last hope. I purchased the fluid from Summit Racing for $160 and flushed it myself.
Amateur tips:
If you decide to do the flush yourself, do not pull ½” line on the cooler or the top one You’ll being changing your motor oil too! Do not ask me how I know this.
A quick overview of how I flushed my transmission.
1)    Pulled 3/8” transmission line out the cooler on the passenger side. I did the by pulling the black keeper down and removing the E-Retaining clip. I then pushed a 3/8” hose in the cooler and a 3/8” hose over the trans line and fastened them into a 4-quart bucket.
a.    If you are doing this by yourself make sure to be careful. If the hoses are not fastened or held down into the bucket, you could make a big mess.
2)    You or your helper (Preferably a helper) turn the vehicle on. Fluid came out of the transmission hose and not out of the cooler. I am not a mechanic but, in some videos, I watched, I have seen fluid pushed out of the cooler. There is a lot of pressure from the pump in the transmission, if a hose pops off, you are going to want someone to turn the vehicle off.
3)    With both hoses placed inside a bucket with measurements on it, have your helped turn the vehicle over until there are four quarts or you start seeing bubbles. Kill the truck and do your pan drop.
a.    Pan drop pro tip. The pan is extremely difficult to get out because the exhaust is right under the pan. If you place a jack on a board and a strap under the board rapped around the exhaust. Pump the jack up to the frame and tighten down on the strap, slightly pulling the exhaust down (1/4”-1/2”). It does not take much.
b.    Second pro tip. Purchase a handheld pump from the part store or Walmart. They range from $7-$20. Use it to pump the fluid out of the pan when drop. It will prevent you from making one big mess and covering you and the floor with transmission fluid. Trust me, its worth it!
4)    Pull the pan and clean it. The gasket is reusable. You can purchase just a filter from the part store for less than $40 or both for less than $50.
5)    Tighten bolts in a cross pattern and re fill transmission with either 8 quarts or however much you were able to get out. I measured exactly 4 quarts in the pan.
6)    Once its filled, have your partner drain another 4.5-5 quarts out while shifting through P,N, and Drive. This way you get out as much as you can in the transmission. The fluid should be clean and pink.
7)    Fill the transmission back up with however many quarts you pull out MINUS ONE!. This way you can put one or two bottles of Lucas Transmission Non-Slip. This is also supposed to help with the shuddering issue and allowing your seals to swell. This is to prevent leaks.
a.    I was able to put two bottles in.
?    Do not add Lucas additive until the transmission is at operating temperature. You will need to fasten the trans line back to the cooler making sure the E Clip is fastened securely.
9)    The transmission should hold somewhere around 12.5 quarts. I purchased 14 from summit to make sure I had enough to flush out the old (Fluid comes out clean and pink)
10)  DO NOT OVER FILL TRANSMISSION. Watch tons of YouTube until you are comfortable. Add a half a quart at a time and allow it to run down the tube (where the dipstick goes, 10-15 minutes) before you check it again.
If anyone would like to reach out to me regarding this issue, feel free.
Fluid:
https://www.summitracing.com/parts/mob-124715-1
Here is a helpful link provided by Chevrolet giving details on the issue.
https://gm-techlink.com/?p=11127
I have experienced this very same things and have been going crazy trying to figure it out. 2014 Silverado Crew Cab 2wd 5.3L w/ 110k miles
New tires at 60K (Micheline tires)
Tires re-balanced
New pads and rotors
New shocks
U-Joints replaced
Drive shaft balanced
Torqued U-Bolts in rear to 70 ftlbs
I will be purchasing this fluid and have the transmission flushed.
Is the Lucas additive necessary? I don't think I want any seals to swell on me. Nothing is leaking on me now.
Its not necessary, but I have done a lot of research and to me, it wont hurt to put 1 or 2 bottles in your transmission. Its supposed to help your transmission as they get older. Its personal preference, I try and take extra measures. That way I know I tried everything.
Follow up on here so I know how it goes. I hope its the solution for your problem. I almost sold the truck because of it.
Is this just a shake? The problem i'm having is a rhythmic humming noise when driving at highway speeds (55mph+)
Humming lasts for 1 sec and then 1 sec of silence, 1 sec of humming, 1 sec silence and so on.
Doesn't matter on or off the power, or in v4 or v8 mode. So it's speed related not rpm related.
David,
The "shake" occurred around 55mph (It was slight vibration around this speed) and around 73mph-75mph+  my console would shake back and forth. I did not record it but i will attach a link, from a guy on youtube that was experience the same issue.
1 minute ago, garrett0151 said:
David,
Thanks for the info, i'm guessing my problem is not the chevy shake than... mine doesn't really shake it just has a slight vibration in the floor/gas pedal with that rhythmic humming noise...
David,
If you ever have the opportunity to record it and stick it on YouTube. Post the link on here so that I can check it out. I'm interested in the issue your truck is experiencing. Its ironic that were having different issues right around the same speeds. You might look up some information on the torque converter shuttering in transmissions. Its not just the Silverados that are doing it. Its been a recurring issue on various vehicles transmissions.
Good luck,
Garrett
10 minutes ago, garrett0151 said:
David,
Good luck,
Garrett
I took it to a transmission shop he didn't think it had anything to do with the torque converter shudder... i'll have to see if a recording will pick up the audio of that noise. If it does i'll make sure to post it.
Thanks
Thanks
How many miles are on your truck?  If you are at 30k or more, it wouldn't hurt to do a transmission fluid change especially if you plan on keeping the truck.  Then you will know for sure if that was or wasn't the issue and know that you are good for a while on the transmission.
Using a quality synthetic in the transmission will help on heat transfer and keeping it clean.  As well as being able to tolerate higher temperatures than a standard ATF fluid.
It is good to hear that one found their issue with the shaking.  Could it be the same for everyone?  Who knows, but like I said, if you have miles on your ATF fluid it doesn't hurt to change  it out and that will eliminate one other item that could be causing the shake.
That's true it could be worth a shot, I purchased it used with 74k miles on it.. I've taken it back to the dealer I got it from they blamed the tires... I took it to another dealer they couldn't figure it out kinda blamed the tires as well.. Transmission shop told me it was probably the driveshaft... had that pulled out and balanced as well. The few shops I've taken it to strongly disagree on it being my tires... only the dealer is pushing that idea. I know what a tire sounds like as well and its nothing like the noise my truck is making.
If you plan on keeping it I would change out the fluid.  There are Youtube video's out there for you to do it yourself or you can take it to the dealer.  The dealer charged me $90 to change out the fluid.  I provided them the AMSOIL ATL.  I took in 16qts to make sure it all got changed out.  If you are interested, let me know and PM me your address and I can send a quote of the cost delivered to your door.
David,
I wouldn't flush your transmission unless you're certain that there's been prior maintenance (flush and or pan drop) on the transmission. If you aren't sure and don't intend on using the Mobil 1 Synthetic LV ATF HP 124715 to flush it, I would recommend a pan drop with the recommended transmission fluid that is provided in your owners manual. Keep up with these pan drops every 30k.
The reason I say this is because ive flushed my transmission at 120k on a 2012 Avalanche with no prior pan drop or flush and ended up having to rebuild it. This was also the case for a 2007 Avalanche with only a pan drop at 110k and a flush at 160k. I lost both of these transmission with no more than -2k on it after the flush.
From my understanding, if you do not flush or pan drop before 60k, the clutch material in the fluid helps the clutch disks grab so that your transmission can shift. If you remove this material, your transmission can start slipping. I did a pan drop at 61k on my vehicle so I was comfortable on this one to do a proper flush and cut the risk of damaging the transmission.
From my research, if you dont pan drop ever 30-60k, DO NOT flush UNLESS you're having issues that your mechanic or dealer recommends you flushing it. AKA Torque converter shutter.
If the fluid in your transmission is bright pink then you could assume there's been prior maintenance. If its really dark pink with some or a lot of black, DONT FLUSH! Pan drop if it still has some pink. If its stone cold black, ride it out as long as you can. The probability of it slipping are extremely high.
If you're 80% certain its a shutter then "I" (NOT A MECHANIC) would recommend flushing it. Dont flush unless you want to spend 3k-5k on a rebuild.
Garrett (NOT A MECHANIC or a DEALER)
15 hours ago, garrett0151 said:
David,
Thanks for the advice, i'm really not sure what to do... it seems like i'm spinning my wheels and wasting money on trying to find a fix.. If I wasn't going to be upside down I would get rid of it in a heart beat.
Hopefully its just annoying and not causing any real problems, besides driving myself crazy.
Hey Garrett, we chatted about this on the youtube video about this topic a few days ago. I have a 2018 1500 with the 8 speed transmission.  I was all ready to handle it myself, but found my truck has no dipstick and apparently its a complex series of temperature change requirements when refilling. Called the dealer and they told me if it panned out that it could be covered under the warranty. Lucky for me I was still under drive train warranty. Went to the dealer today and they did the flush out of the original fluid. So far on the 35 minute ride home the shudder is gone. They asked me to check in with them at 200 miles out and let them know how its going. Will bring an update here as well.
Hey John,
Good thing you were able to get it to the dealership before your warranty was up. I had a hard time getting them to do anything. Luckily, I bugged them enough to get some information out of them.
For my situation, GM extended drivetrain warranties for only a select number of 2016 Silverados. My VIN was not one of them. Same situation for a bad a bad condenser. They wanted $1,800 and I fixed myself for $150.
I can't believe GM would allow an engineer to design a transmission with no dip stick on it. Blows my mind!
Follow up in the future and let us know how it's working out for you.
Garrett
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
