4 hours ago, Dunn said:
 I would just piece it out.....or mix and match....probably the diff would need addressing as well
get UCA of your choice, buy some keys, buy a block and get shocks you want.....would at least put an eibach or bilstein shock on there...they are afterall suspension companies...KING or Fox would be really nice ..that would be my thought anyways
they all look the same at any given height ....put some decent shocks on for sure...
yeah my installer ended up getting his hands on a ReadyLIFT 3.5"/3" kit that I'm going to have installed next week hopefully with the new wheels and tires!
Who are you using? I've used Rocky's Tuff Trucks in Gallatin 2 or 3 times. He's great!
yeah, i got referred to Rocky from another buddy! That’s who is doing it all!
Awesome! Congrats. I work in the music industry and thats how I found out about Rocky. Most of the country music artists in Nashville use him for their truck builds.
yes me too! he’s been great so far. will post pics after i’m finished!
Superlift also makes a nice 3"lift which i seen nobody mention. I'm getting ready to install mine in the next week or 2 just waiting for my wheels and tires to get mounted. I've seen a couple people on here that have them. Looks pretty good
Sent from my SM-A705U using Tapatalk
Just installed last Friday. Very happy with setup. Shocks are a little stiffer than factory Z71 Ranchos but still rides very nice. Installer who does all the lifts for local dealer where I purchased indicated this kit has made major improvements over prior Rough Country kits. He seemed impressed with it and ran into no problems with the install.  Running 315/60R20 w/ 20" x 9"+1 offset wheels. Very small trimming to the lower plastic valance that I ultimately took off anyway.  Looks way better without.
yes my installer insisted that it was a great kit and that rough country isn’t the same quality of old.
i still wanted better shocks so i opted for the Readylift 3.5/3” SST kit!
If people were on the fence like me, and I had access to good shocks, i’d put the rough country lift on there and replace the shocks with fox or bilstein shocks instead. you’re looking at about $1000 all in... and still the cheapest 3” lift kit out there!!
11 hours ago, FlCajun said:
..Running 315/60R20 w/ 20" x 9"+1 offset wheels. Very small trimming to the lower plastic valance that I ultimately took off anyway.
was that the only trimming you did?
looks great
Superlift has a kit with ucas cheaper than the rough country
true. About $100-120 cheaper and you don't waste the purchase of the shocks that come with RC lift!
Yeah I heard the rough country shocks were not good. I'm gonna try the stock ones first if not then I'll get the billsteins
So I’m assuming you’re talking about this kit
https://superlift.com/?d=855&dt=80
It says it fits 2500/3500 but doesn’t fit with overload springs. I’ve never seen a 3500hd without overloads so wtf are they talking about?
Yes that kit. I've got it sitting here waiting to install it. I've sen some pics from others that have it looks nice when finished.
Going into a 2500 or 3500 with overloads?
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
