LED headlights
Good morning all, I'm looking to remove the halogen headlights and install LED lights. Does anyone know if the 2015 Silverado 1500 is a CANBUS system? If so what LED lights and defeaters did you use? Thanks
Sent from my SM-G965U using Tapatalk
  • Replies 37
I forgot to put that in my initial post. I have reflector headlights.
Don't put LEDs in if you're not willing to pay the premium for ones that mimic the halogen, such as diode dynamics SL1
If it was me I would stay away from any LED that has a fan.
I like these. Best warranty, nice price and no fan.
I have been debating getting these LEsS for all my truck lights. High , low and fog.
Through emails with this company they say they design the LEDs for each application.
https://www.headlightexperts.com/carfinder/?find=2015-chevrolet-silverado-535429
Now I'm leaning toward and LED light bar. Great light output, less money.
Horrible advise. Fans are how they cool. You listed overpriced garbage that will blind other drivers.
7 minutes ago, diyer2 said:
Another know it all.
Read the reviews on yours then mine. Look at the product pictures. Look at the company reputation. Who wouldn't spend $50 more and get the best product for this application? The ones I listed are actually showing his vehicle unlike the generic ****** pic others use.
OK, you have your opinion and I have mine.
Agree?
Your brand has no high beam LED.
3 year warranty.
Reviews are opinions and I like to evaluate things myself so reviews don't mean a lot to me.
I didn't recommend the brand I like to start an argument or a debate.
How do you know my brand is garbage and will blind other drivers?
I don't mind you posting your opinion but your not an expert.
And by the way I don't hold experts in high regard either. Expert or not it's an opinion.
Done.
I certainly appreciate the input. Does any one know if I will need the warning cancellers? My last car had a CANBUS system where the computer monitored the whole car.
You do not
I would not buy the junk from headlight experts posted above. I would buy the diode dynamics bulbs.
Putting led's into projector housings is generally a bad idea because most LEDs are not designed  for that type of housing, they're often cheap sales gimmicky products that won't give you a good result. It doesn't matter how bright the light is if you are spraying it everywhere but the road.
And Led's are okay, but I prefer a good HID retrofit to led light, maybe in the future LED's will catch up
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 488 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
