Cold air intake IATs spiking
This is the actual truth
I bought a "Cold" Air Intake and felt the truck being more sluggish
Did a log, Hello, 120*F intake temps
I reinstalled my AirAid Intake Tube with the stock AirBox and Filter, truck went back to normal
My 2 cents is get rid of those intakes and reinstall the stock one. And if you want more flow, get a Geen Filter or any drop in filter for the stock airbox
I have had the AirAit MIT for a couple of years now, and im happy with the performance of the truck
Cheers
That's what I have. The stock air box, better flowing filter, and the Airraid tube. It all just helps it breath better which is all that is needed.
Sent from my SM-G975U1 using Tapatalk
On 6/13/2020 at 11:12 PM, Grumpy Bear said:
There use to be an exhibit at the museum of science and industry. A chess board where every square was a different material. Each square about 4 X 4. The materials were heated from below to all be at the exact same temperature. You put your hand on one at a time and they all felt like they were quite different. Wood felt warmer than glass and so on. The material will change the amount of time it takes to reach under hood temperature but soak any material long enough at the same temperature and it will be at the same temperature. I wouldn't worry about it.
Yes but in the real word the r-value is exactly what’s important because all that matters is how fast energy can be transferred.
It’s why your outside surface of your freezer will always be near ambient temp.
The only time r value does not matter is if said object is exposed to the temps on all sides of it.
How many air changes are occurring within the volume of the intake tube over a given period of time? Should be pretty simple to calculate. An engine is an air pump right? Inhales and exhales, that's it. Increase RPM and it breathes faster. A 5.3 is 325 cubic inches, which as you know is the volume of all 8 cylinders combined. It takes two complete revolutions of a typical 90 degree crank to complete the firing of all cylinders. So, in one engine revolution it has inhaled approximately 162.5 cubic inches. This is assuming 100% volumetric efficiency though. With the engine idling at 500 RPM, that's 8.333 revolutions per second, or, approximately 4 complete firings of all 8 cylinders. 4 x 325 = 1,300 cubic inches. But at idle VE is probably only 50%, so let's cut that in half and say 650. That's 650 cubic inches of volume every single second.
Hold that thought.
What's the volume of the intake tube? Let's assume it's 4" diameter and 24" long. It's actual volume is probably smaller, but I'm being generous and using round numbers. That yields a volume of ~300 cubic inches.
That means about 2 air changes occur in the intake tube every single second. And this is just at idle. At 2,000 RPM there are 15 air changes occurring every single second.
This should illustrate that heat soak of the intake tube itself doesn't matter one bit. You cannot heat air that's moving at that kind of velocity. The increase in IAT is from poor sealing of intake box itself. Heat soak is a real problem but the intake tube isn't the culprit.
Oh and someone check my math and logic please.
Hold that thought.
I’ve had that exact thought for years. Yeah it would not be significant. But you add in the throttle body, heads, intake manifold, air filter housing, that’s quite a bit of hot surface area.
Now keep in mind that you can actually change the temp of fast moving air. Simply look at air-air and air to water intercoolers. They are obviously way different than an intake tube though. And certain things that I would assume not matter at all end up mattering alot.
Like who would think hot headers would heat up an engine bay when at 60mph the air in your engine bay is getting replaced like 5 times a second
Yeah i don’t think an intake tube would do diddly squat unless it had fins on the inside and outside and was designed to transfer heat.
You do make a good point about intercoolers,...hmm. I might have to jump down that rabbit hole :)
Well compared to the intake tube, an intercooler probably has like 3x slower moving air, with 10x the interior surface area and 50x the exterior surface area.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
