Cold air intake IATs spiking
Hi,
So I got a cold air intake from k&n but the one I got has a metal intake tube, after taking it to a tuner he informed me after the truck warms up the intake tube also heats up causing my IATs to spike and timing gets pulled. They said to get a plastic intake tube but I don’t want to spend another 300+ dollars on another intake. If I got titanium exhaust heat wrap and wrapped the intake with that would it help to keep the heat off the intake?
thanks,
Daniel
That would be your best bet to keep the metal tube from heat soaking the engine compartment heat.
I also saw that gold reflective tape, do you think that would be more effective?
1 hour ago, Sir Oric0826 said:
Hi,
thanks,
Daniel
There use to be an exhibit at the museum of science and industry. A chess board where every square was a different material. Each square about 4 X 4. The materials were heated from below to all be at the exact same temperature. You put your hand on one at a time and they all felt like they were quite different. Wood felt warmer than glass and so on. The material will change the amount of time it takes to reach under hood temperature but soak any material long enough at the same temperature and it will be at the same temperature. I wouldn't worry about it.
Food for thought here. The IAT sensor is built into the MAF sensor, which it at the start of the intake by the air filter. In the very short time that the air is in the metal pipe after the sensor the computer doesn't know what is happening there because there isn't a IAT2 sensor post intake in the plenum. So it can't pull timing based on the temp of the air after the MAF.
You really just need to worry about the temps before the MAF. If the intake you have in open to the air under the hood, that is part of the problem for high intake temps. A sealed box like the factory is the best option to be honest as it pulls cool air from inside the fenderwell.
My intake is stock and on the road never reads more than 2 to 3 degrees over ambient. Sitting idling at the take out window it gets a bit warmer. :) Factory inlet is a cold air system.
Haven't we all decided that the factory setup is better than any CAI?
There’s been studies that show CAI and exhaust offer improvements. Not as much as in the past as the auto manufacturers used CAI with sound deadening. And multiple mufflers, resonators and cats that flow really good . If you put an aftermarket CAI and it’s not sealed probably you have the opposite effect. Opening the exhaust you have sound probably not enough horsepower to feel the difference. So is it worth the money? That’s debatable. My last new truck 2014, I did muffler delete. I gained nothing in my marked off area. My personal test area for 40 years. My younger days I would have done it anyway. I had too that’s just the way it was. If you hear it, it’s faster. It’s just money, right?
I would go back to stock.
CAI isn't worth it.
In the early 70's when all this EPA watchdog stuff got started and the OEM's got blindsided with the un-doable getting large gains was pretty easy. Not as easy as pre-regulation, but easy. Today there are only crumbs left on the table for NA motors.
Cost per hp has gone too far north for me to chase. Yea, you can get a few ponies with this and that but boy...$$$$$/HP!!
Well said grumpy! That's all r-value for insulation actually tells you. The higher the value the longer it takes for heat/cold to penetrate.
Hi,
thanks,
Daniel
I suggest you find a different tuner because they dont know what they are talking about. The tube has nothing to do with the IATs and timing being pulled. You are probably pulling in hot air at the box. Stay away from open box CAI and go with a closed one. In my opinion if you want a CAI is to use stock box and just have a different tube like an Airaid MIT or something.
Sent from my SM-G975U1 using Tapatalk
I saw a guy plumb a tube from plumbing PVC glued up that worked well. Painted it flat black and it even looked nice.
This is the actual truth
I bought a "Cold" Air Intake and felt the truck being more sluggish
Did a log, Hello, 120*F intake temps
I reinstalled my AirAid Intake Tube with the stock AirBox and Filter, truck went back to normal
My 2 cents is get rid of those intakes and reinstall the stock one. And if you want more flow, get a Geen Filter or any drop in filter for the stock airbox
I have had the AirAit MIT for a couple of years now, and im happy with the performance of the truck
Cheers
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,522 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
