2018 LTZ 20" Wheel Swap
Hello all. Got ny 2018 Silverado LTZ and it has the 20" chrome wheels on it. Rides pretty rough and can feel every bump on the road. Use to my 2006 with 17" on it.
So the question for discussion is if I placed 18" or 17" on the LTZ will the wheels/tires be too small looking and not fill in the wheel well?
Also, will the LTZ ride smoother?
Anyone done this type of swap out yet?
So what you all say as I new to this truck.  Thanks in advance for input.
If the 18's have the correct size tires they will be pretty close in size to the 20's. You can look at pictures or just other trucks on the road to see what it looks like.
More sidewall with good tires should ride better than 20's with less sidewall.
GM trucks come with tires of roughly the same diameter/circumference. 17's have a lot of sidewall, 22's not much at all. As said, more sidewall equals softer ride.
I have factory 20's on my LTZ and the ride is great. I run 18's in the winter with the appropriate sized tire and the ride is also great (more sidewall) so if you drop down to a 17 (or 18) with the right tire you will be good.
What size and brand tire do you have on your wheels now? If they are lower quality or a small size that will affect the quality of the ride.
My 2018 slt premium plus came with those horrible “Chrome clad” 20” wheels that are actually an aluminum wheel with a PLASTIC chrome cover glued on. Premium my azz.
I’ve since sold those and went to 17” BFG 285/70/17 for winter. They are load range E and honestly ride is about the same.
I have 18” AT4 wheels 265/65/18 Goodyear wrangler fortitude HT for summer and they are a little softer than BFG and stock 20” but not much. I run 44 psi for better wear and mpg. Lowering air pressure to stock 32 / 35 psi hardly makes a ride difference for me.
I’m running Bilstein 5100 shocks as well so that stiffens everything up.
My truck is max tow so rear springs are stiffer and possibly front as well vs a standard half ton.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,211 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
