Does anyone have a photo of the ac drain location. Can’t find the damn thing. I have to be blind
Look right above the exhaust pipe or muffler, I read where they have it drain on it to stop from leaving puddles of water on peoples garage floors. People said they can hear it hissing when they first shut off the pickup.
On your '02, it's on the passenger side firewall, and is too far away from the exhaust to drip on it.
Google "gmt800 ac drain" for pics/videos of it and how to clear it.
Sorry... not 02. Old profile pic from 18 years ago. It’s a 2020 and can’t find it. Found a parts diagram but that didn’t help
maybe update your sig as well, as it doesn't mention anything about a '20
Ah. Gotcha. None of that shows on the app.
Mine's been draining in the cab on passenger side since Friday... Thank goodness for the Weathertechs! I will be making a phone call Monday morning.
I just replied to your post. Might be more to your situation as well
  • 2 years later...
So I have the same issue. Passenger side carpet gets damp, I’ve pulled my weather tech mats and the bottom is damp just in the
Middle. When AC runs there is a good drip from The condensate line running to the pavement. (Appears to be working right) I leak tested windshield, back brake light, etc and never seen any water. The floorboard on passenger side is getting HOT. I cannot figure this out… and it’s starting to smell.
    contrabombarde
    contrabombarde
  • Who's Online   5 Members, 0 Anonymous, 1,158 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
