does anyone knows what that means.
at my local dealer nobody knew. i was trying to get the rear driveshaft part #. but it came up with two different ones.
part # 15109400 w/broadcast code nk7 & # 22845686 w/broadcast code pl4.
no one knew what “w/broadcast code” is or was, or where to find that code on the truck.
thanks
Edited by Magic Wheels
  • Sad 1
Those look like RPO codes to me. The RPO code list should be on a sticker inside the glove compartment.
I can't believe the dealer staff do not know what a broadcast code is.
Broadcast code and RPO are the same thing.   They use broadcast codes in assembly processing language instead of part numbers.  That code will often be found on a sticker on the part that was placed by the part manuf.  Linking together all production depts and suppliers is an electronic broadcasting system that assures that the proper parts for a given vehicle will arrive at the proper place at exactly the right time.
NK7 FUEL TANK,117 LITER(31 GALLON)
PL4 Tire option
Build sheet = Broadcast Sheet
RPO - Regular Production Option
LPO - Limited Production Option
Vehicle build info.....
Order status codes:
1100 = Preliminary Order (Order passed GM edit tables but dealer has not received allocation to place order)
2000 = Accepted By GM (Dealer used allocation to place order into production)
2500 = Preferenced (Order pulled to the production system)
3000 = Accepted By Production Control (Order input into the production system)
3100 = Sequenced (Order sequenced for Production)
3300 = Scheduled For Production (Order is scheduled into the plant build cycle)
3400 = Broadcast (Order is sent to various build & supplier areas to bring order together)
3800 = Produced (Order is built and VIN# shows in the Dealer Order system now)
4150 = Invoiced (Order is invoiced to the dealer)
4200 = Shipped (Vehicle is shipped to the dealer or point of delivery)
5000 = Delivered To Dealer
6000 = Delivered To Customer
Edited by elcamino
  • Thanks 1
broadcast sheet full of broadcast codes
Broadcast-Sheet-1996-Chevrolet-Corvette-
Edited by elcamino
  • Thanks 1
Ahh, thanks for the info, Mike.
In all the years I've been around cars, I've never heard that term "broadcast" when referring to RPO codes. Good to know. ??
fyi..................
I found the build sheet of my '72 El Camino above the gas tank. It was in rough shape, so I probably missed the "broadcast" labeling, since half of it was illegible, or missing.
i guess i found my truck’s broadcast code sheet and the part # is 15109400 for the driveshaft.
thank you guys i really appreciate your help.
  • 1 year later...
Trying to decode   N1212371MFRX0261 from my engine traceability label, dealer not being very helpful in doing so.
Anyone have access to decode this?
Thanks in advance.
    juggernautusa
    juggernautusa
  • Who's Online   4 Members, 0 Anonymous, 1,194 Guests (See full list)
