Just changed the spark plugs in our '08 5.3 Tahoe.
A bit of advice for anyone not having done it and giving it a try, get a plug wire boot remover pliars and a 1 1/2" long socket extension for the #8 plug. It's still fishing in a blind spot, sticking a probing finger in there and hoping for good luck or an answer to prayers. The air conditioning drip tray makes wrench and hand access VERY difficult at #8. Prepare to have scraps on your hand and arm.
Edited by Beamie
Aw damn yeah did you try and remove the fender liner? I don’t when I do them but some of you kids may want to.
You can also take off the manifold heat shield so your hand can get back there easier
Being 12 years old, 100,000 miles in the land of aggressive winter road chemicals nothing comes off our truck with breaking.
Started down that road, took the wheel off, looked in there and I don't think that is the answer on our truck.  It's that darned air conditioner equipment, drip tray and hoses that obscures the spark plug.
Oh. I see. I have an easy 3 step process for rust, not too bad anyone can do it.
1. Sell that truck.
2. Move down south.
3. Buy a truck from the south
I tried it and it worked great no rust at all!
1. Sell that truck.
2. Move down south.
1. Can't afford a $70,000 replacement.
2. and 3. If we went south it would have to be near the ocean, so we'd be going full circle with the salt (just can't stay off the sand!) and missing snow at Christmas.
Guess we're stuck with rust and the Tahoe.
Try? DID
couple of screws and a hand
full of pushpins
sat on a stool and changed all four
no strange contorsions over the fender
we are not as talented as you are, or as smartasssy!
Try? DID
full of pushpins
LOL it’s taken me years in a shop to perfect my smartassy-ness
Ugh Florida cars can be just as bad as Michigan cars...
I worked at a Nissan store where the guy parked his Sentra with the driver side facing the ocean for about a year and a half.
2,000 mile car and we had to replace both front and rear brakes because the driver side pads and rotors were frozen solid with rust! Wheels pitting all the exposed medal rusty.
If you went to the passenger side, looked like a new car!
4 hours ago, nqabigt said:
Try? DID
full of pushpins
Mine appears to have two anchors put in from above under the battery tray which I didn't want to muscle around with. Not sure what they are holding but that and the face that the mudflaps are also involved in the inner fender cover was too much to mess with.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
