I have a 2011 Chevy 2500hd with 6.0. The truck has developed a misfire at idle and partially on the gas. I have replaced all the spark plugs, all 8 injectors, moved coil packs around, replaced MAF, MAP, b1s1 02 sensor (was getting codes for that sensor only), ECU, fresh gas and added cleaners, cleaned throttle body and swapped throttle body, had cats removed (already were blown out and empty) Nothing has solved the issue. Only bank 1 is misfiring. Mainly cyl 1 and 3. The truck backfires out the exhaust, and under load back fires out the intake. It will clear up like a switch flipped and run fine until the truck is shut off and restarted. I’m at a complete loss. By watching the snap on scanner. It appears as if it’s richen bank 1 and lean bank 2. I’m at a complete loss. It’s happening at idle and slightly off idle until it decides to clear up. I have been getting codes for random misfire and bank 1 sensor 1 02 sensor for heater issue.
I was thinking possibly crank sensor or cam sensor but what doesn’t make sense to me is that it is only misfiring on bank 1 and not bank 2. And that it is fattening up bank 1 and lean out bank 2. Atleast the pulse width for the injectors is showing off on each bank. When it runs fine they are equal. If not they are off by a lot. Like 3.5-4.0 and 1.5-2.0
?,that backfiring in intake,leads me towards crank sensor,one test is watch rpms on scanner and spray cool water on crank sensor,see if it changes anything, another is,move wiring a little for crank sensor,anywhere it's accessable,and safely
I’ll have to try the spray on the sensor as that seems a little easier and safer. It will backfire through the intake under load. No load at idle it back fires out the tail pipe.
I haven’t done the test with the water. I had a spark plug that burned out (it had maybe 1500 miles on it) and I had to order a new set of plug wires for it. I’m gonna replace the plug and put new wires in it. I’m going to replace both up stream 02 sensors as well with new bungs. The threads on bank 1 are messed up and the sensor doesn’t seat fully into the pipe.
I replaced the bad spark plug today, along with all of the wires, the body to motor ground, and cleaned the main engine ground. I did notice that the wiring inside of the loom is rather brittle and corroded. I will be replacing the main ground from the battery to the engine. Here are some of the graphs that the scanner is showing. What I’m noticing is that bank 1 (side that always misfiring) 01 sensor number 1 is not nearly as “sensitive” as bank 2 sensor 1. Also fuel trims between the 2 sides seem to be off as well. a5a49ab3afb2c2af925c506bd6eab045.jpg
  • 5 months later...
Okay. Little update if any one is able to help. I replaced the ground cable that was corroded. I checked for power and ground at all the sensors. When I use the sensor grounds, I get 8.70 volts with key on engine off. If I use the sensor positive and the ground of the motor, I get 12 volts. Where do the o2 sensors ground to? I have replaced the factory ground to the battery as well as firewall to rear head ground. Still no luck
  • 6 months later...
6 hours ago, 94TBI said:
Did you ever resolve this issue?
No I have not. I have replaced grounds and cleaned ground points but cannot find the issue. I’m leading towards a wire in the harness or possibly corrosion within a ground wire somewhere. It’s driving me crazy. Recently I’ve had service trailer brake system and trailer wiring. The trailer brake relay was recently replaced and is new. So with the misfire, and now these other issues popping up I’m going to say a ground wire. The trouble is finding which one. I’ve replaced the battery ground cable, rear head tires body ground (which was previously blue and fell apart) and cleaned frame grounds under driver door.
Also to update, I did replace the crank sensor. No change. I’m going to try to replace both downstream o2 sensors. The one on the driver side looks like a universal one that you use butt connectors on. Maybe the downstream one is throwing the upstream off or something? Not sure being hopeful at the moment. I’m running out of options. Trying to get the issue resolved so I can sell the truck to get a full 4 door duramax.
Yeah I know. It’s about the last effort unless I change out the whole wire harness. I have literally replaced every other sensor. Or I am going to take it to the dealer and pay for the diag and see what they come back with. I’m about out of ideas at this point.
Edited by casey.mikl
Have you checked for compression and spark? Have you also used a noid light on the wiring harness to see if all the injectors are pulsing fuel?
What codes are you getting?
Maybe these are some dumb questions but just want to double check all the basics. I would also suggest take it to the dealer before throwing more parts at it.
Yeah compression and spark is fine. I have not checked the injectors. When it’s in closed loop it misfires and runs terrible. When it’s in open loop it runs fine and has no issues. I have replaced maf, map, crank sensor, battery, all ground cables, injectors, plug wires, spark plugs, computer, o2 sensors upstream, cut out cats (starting to come apart). I’m going to take it to the dealer. I ran it today and running using the computer as ground I’m getting 14.6 volts. Also same on body and engine. I had a feeling it may have been a ground to ecu issue but it wasn’t.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
    • $2.20 E-85 down from $2.59 Around $3.80 for regular and about $5 on average for Premium.  Propane $3.99 a gallon.
