AC broken
So my 14 Silverado has about 60k miles, belt broke between the crank and AC compressor. Found out the compressor was completely locked up. Replaced the compressor and expansion valve, new o-rings as well.
Brought it to get evacuated and recharged, and was told there’s no leaks. They put just under 2lbs in, but I still have warm air.
I only have a gauge that came on a Freon can, and the low side is way high, around 140. Compressor and clutch are both working fine.
Any ideas what the problem could be?
Are you sure you are plugged into the low side?  Your low side PSI should be between 30-35 PSI.  It's likely not turning on if the low side pressure is that high.
Next thing to check would be Schrader valves with leak detector.
If your compressor lock up you you could a clogged condenser, it's always a good practice to replace the condenser and flush the system.
^^^ +1
No one is seeing the problem from what he said? lol
You have too much Freon in the system.
Your truck only holds 1.4lbs of Freon. If they put 2lbs in it, Your pressure are going to be way out of range and your system will not work correctly.
Take it to someone who can recover, vacuum and recharge your system correctly.
So I picked up a set of AC gauges. Both high and low side are about 108. If it were overfilled the high side would still be reading much higher, right?
Everything I read is pointing to a bad compressor, but it’s got a brand new AC Delco compressor. Clutch operates as it should, on when the AC button is on, off when it’s not.
Checked with a UV light, no leaks anywhere that I can see.
im pulling my damn hair out and I’m bald, so it’s tough ?‍♂️
Following as I seem to have the exact same issue.  Been fighting it off and on all weekend.  I think full charge is 29oz, but I never saw any differential across my compressor from 0 all the way up to 29oz, both high and low side topped out around 120psi and just sat there.  Clutch works fine, but it doesn’t even seem to load up the engine when it kicks in.
Brand new condenser (the beginning of the issue), no leaks, held about -29psi for 2 hours.  Doesn’t leak under charge either.
Not my first rodeo, this is my 4th condenser (one due to an accident), and I’ve replaced and charged them all.  This time, I think the compressor bit it too :(
No. Never diagnose your vehicle using static pressure. So many people make the mistake of using static pressure to "Know" whether the system is charged full or not. The static pressure in a vehicle will correlate to the ambient temperature outside. 108PSI is about 90 degrees outside (I make that knowing that 100 psi is 86/87 degrees ambient) If you buy diagnostic gauges it will actually show you this on the gauge setup (the temperature that is) But in general, static pressures in a vehicle are useless because if your system is overcharged you are going to see very minor increases in static pressure to ambient temp.
So, here is what I did. I charged a system to full. Today it was 98 degrees outside and 103 in the shop. After 20 minutes of letting it sit there charged, I looked at the static pressure. It was at 104psi. When I cranked the vehicle it ran at 35/200 which is fine with the humidity. Cooled to 41 degrees out the center vents.
I force charged another 0.50 lbs of freon in the system bringing it up to 1.90lbs. After 20 minutes of letting it sit untouched the static pressure was at 110psi. When I cranked the vehicle and let it run, It ran at 43/305 and kept cycling.  Cooled to 68 degrees out the center vents.
Recovered and recharged the system to the correct amount and temperature was back down and cooling properly.
You can change your compressor if that's what you want to do. Just make sure they put the right amount of freon in the system this time and you will be back to running properly.
You keep saying you are pulling your hair out, But unless you put the wrong information in your primary post... The answer is right there. 2lbs of freon is too much. It's doesn't make it run any better with more freon in the system.
What is your high side and low side pressures at then the system is running?
Update on my situation.  Compressor was locked up, shaft sheered between clutch and compressor.
That was the pressure when it was running, clutch was engaged. Regarding the 2lbs, that’s what I was charged for. It was a shop that did the work evacuating the system and refilling it, I’d have to think they looked the specs up and just rounded it up when they charged me. Even if it were overfilled, wouldn’t the high side pressure be higher when it’s running and the clutch is engaged?
Both the high side and the low side are at 108 while it is running ans the compressor is engaged?
Back in the day... the old GMs.. ran A-6 compressors. they ran at high rpm, never overheated.. and when revved they were like 3 ton units.. cast iron  and 6 pistons... fast forwarding... when i pass a vehicle.. i disengage my AC not to over-rev it or let it at high rpm for extended periods... once they let go... it is hard to get them back in shape without starting over with everything.. my experience...
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 914 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
