The 2015 Silverado 2500HD gets a 6.0L Vortec V8 standard that cranks out 360 hp and 380 lb-ft of torque. When equipped with that engine, the Silverado 2500HD can tow up to 13,000 pounds with a conventional hitch. Upgrade to a fifth-wheel, and you can pull up to 14,800 pounds! Was their advertisement, wonder if its true. I know i am at the max and would live a diesel but doesnt suit my daily driving habits.
Sent from my SM-G960U using Tapatalk
I pull a 34.5 foot toyhauler with 2 Atv's in it, 160 gallons of water, 45 gal. if gas. Tops out at 14,000 lbs. My Silverado 2500hd 6.0 gas pulls it well. I currently have Doug Thorley shortie headers that are ceramic coated on the inside and the outside to keep the heat in, Afe cold air intake, and a free flowing exhaust,along with the 4.10 gears and a Blackbear tune. She runs well but to help I kept my tires a little smaller to not lose my gears, running 275/75/18 tires that measure out at 32 diameter. I do have a Magnuson 2300 supercharger on order just waiting for Blackbear to ship it. They are going to do the tune for it too.
Sent from my LM-G820 using Tapatalk
Let me know how the tune goes, def wanna do that. Searching for long tubes. I find for up to year 14. Curious if there is a difference from 14 to 15
I am quite surprised at how many people tow that heavy with the 6.0. In all honesty, I couldn’t imagine hauling much more than the setup I have without going to a duramax. Good to see that these trucks can take the abuse though
I wanted a diesel. This is my daily commuter. My average drive is 10 to 15 minutes stop light to stop light. Gas mileage is eh, but i run e85 at 1.59 gal vs 87 at 2.09. I weigh in at 7700lbs with me in it and some tools.
We just bought a Cougar 5th wheel - it's 9400# empty with GVWR of 11,500. Loaded to take to camp it towed awesome, but I don't think I'd want to be right at the 14k limit of a 2500 Gasser.
Nice, im.waiting on the rv place. They wayyyyyyyy underbided my trade.
22 hours ago, elgavilan123 said:
Here's a Pic of my setup
Nice looking rigs there. I see tailgate down - I have to be like DEAD STRAIGHT or I can't lower it - your's that close?
No, mine has some clearance, I had just hooked up, don't tow it that way. I use an Anderson hitch, just recently switched from a slider, so the trailer sits about 8" further back. Really like the Anderson, the part you have to put in and take out only weighs 35# so it's really easy. I run a camper shell when not in tow mode.
Was looking into the reviews on the anderson. I like the light weight part.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
