Hi Everyone, first post on here but have been a long time owner of numerous c/k chevy/gmc trucks. I currently own a '99 GMC K3500 crew cab dually pick-up truck with a 7.4 454 vortec engine with 160k miles. I recently purchased this truck just to tow my 7,100 lb travel trailer, not a daily driver. When I purchased it, I put a good amount of money into it, most of the things i did was not necessarily because it needed it but more because I wanted peace of mind knowing I had a truck that I could rely on. The truck drove and ran fine but did have a hard start when cold. I replaced the fuel pressure regulator but figured while I was under the plenum I might as well change out the notoriously troublesome injectors with new Bosh injectors. After that was done the hard start was fixed and the truck ran excellent. I then tested the truck by towing it up a nearby pass to see how it would perform and it severely struggled to go over 30 mph and shifted very hard into gear. I took the truck to the local Chevy dealership and they came back and said that the acceleration issue was a result of a bad fuel pump. I had that replaced and the hard shifting was gone!, and the truck ran even better. I then took it on another test tow and the acceleration was a lot better towing uphill in 3rd however it still struggles to stay above 45 and really has a hard time. So heres the deal, I totally get this is a 20+ year old truck and I am not expecting to do 70 up a mountain pass but do hope I can maintain 55-60 and not feel like we are going to slow down to a near stop when towing up a steep incline. I have been on a camping trip the last two weeks and the truck has been performing great aside from climbing the passe. What I am looking to get out of this post is if there is anyone who has experienced the same issue and what did you discover or upgrade to get the truck performing at a higher level. I really don't want to get rid of it and don't mind doing some minor upgrades like exhaust, headers, ECM upgrade but just don't want to throw money at it for very little to no gain. I have a attached a pic on the rig. HELP!
you might have the wrong gearing in differential for towing in mountains
Edited by Brian Lindsey
I'd crack open the glovebox and look at the RPO label.  Head in to the G and or H section and you should see one of the following codes there:
GT4 - 3.73 gears
GT5 - 4.10 gears
HC4 - 4.56 gears
Also, how heavy is that trailer?  Dry or the GVWR of it is fine, whichever is easier to find.
Edited by newdude
Thanks for the reply so far!
I looked at the codes and I have a GT5(4:10)
GVWR 7600K and Unloaded weight is 6K
Well, it was 4.10's. I say that because those look to be oversized tires compared to stock. So it did reduce your gear ratio by some with those larger tires. Towing performance will go down because of that.
Without a scanner hooked up and possible a back pressure sensor on there, I can't really see what it's doing and if there is a possible exhaust restriction before the cat converter.
Thanks. Yea I purchased with those tires and I had a feeling that would be an issue. Do you recommend going to a 4:56? Or re programing the shift points?
Going to 4.56's would help because of the tires and the added weight they bring but that is a ton of money unless you are doing the work yourself.
It would be half the cost or more to go with smaller/lighter tires and sell the oversized tires to make some money back and make it even cheaper.
Tuning it can help but hard to say how much of an improvement it will make.
Jeeze, you got a 1 ton with a 7.4 liter and struggle to pull a 7,000 lb TT.
Don't show this to the guys with new half ton trucks pulling the same size trailer.
I'd second the idea to go back to OEM size highway tires. What you have on there now isn't helping you on the pavement.
Yea tell me about it. Stock tires say 225 75 16 and I have 235 80 16 on it.
Edited by chevytruc1658
The picture make them look bigger than 235/80's that's for sure but if they are mud tires that are really heavy that is still hurting things some.
Hey everyone, one other question. I got a line on a set of 6 very nice Alcoa 225 75 16 tires (stock size) but they came off of a 2007 Ford E450. They are 16” and 8x6.5 bolt pattern which is the same as the Chevy. I know the hubs on Fords are larger then Dodge and Chevy, and these hub openings measure 4 7/8” Which are in fact larger then Chevy so they should fit right?
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
