I just bought a 2020 Silverado 1500 LTZ and plan to add a Lear 100XQ truck cap to it. The truck has an awesome video rear camera which I use vs the mirror. I'm not talking about the "Backup" Camera. The rear view camera is mounted high up on the rear of the cab, not the tailgate. I'd like to somehow move that camera to the back of the truck cap (or wire in a new camera) and still use the OEM rear view display. Any thoughts?
Edited by PBrown1
add picture
Edited: Nevermind, thought you were referring to the back-up camera.
Edited by Wiggums
11 minutes ago, Wiggums said:
No, you don't need to do anything to it. I would not want to move it anywhere else.
The truck cap will block that camera.
Edited by Wiggums
Edited by Wiggums
I believe that he is talking about the bed view camera that is on the top corner of the cab that is installed to into the third brake light on these trucks.
Sorry for the confusion. There are 3 cameras (rear view camera, backup camera and bed view camera).  The rear view camera is mounted next to the bed view camera high on the back of the cab. On the LTZ (package?) there is an electronic rear view display built in to the rear view mirror. You can use is in video mode or mirror mode. It uses the camera mounted high on the back of the cab not the tail gate. That is what is being blocked.
Edited by PBrown1
Sorry for the confusion. You are referring to the backup camera not the rear view camera. On the LTZ (package?) there is also an electronic rear view display built in to the rear view mirror. You can use is in video mode or mirror mode. That camera mounted high on the back of the cab not the liftgate. That is what is being blocked.
Yes. I am also interested in doing so, been waiting on a topper until I can.
I saw on another post that leer may have been working on something, but never said if it came to be yet.
My apologies, now I get it. Didn't know a thing existed!
Quote
Since they are going into year three on the T1 model, you may be waiting a long time.
No such animal from GM presently and they show little or no interest in requests for a solution when adding a top on the bed.
  • 9 months later...
Gen5diy has an extension cable to go from the drivers side connector above the left rear seat to a external camera in your topper. The cable is 21ft long. plug and play. I bought a taillight assembly on ebay with the factory camera. I made a bracket to mount the camera under the window frame inside the topper. Works awesome. Link to the cable. It is built for the camaro.
https://www.gen5diy.com/products/gen6-camaro-live-view-mirror-camera-cable-spoiler-camera?_pos=2&_sid=c9b13ef14&_ss=r
0?ui=2&ik=f13c396c07&attid=0.1.1&permmsgid=msg-f:1700281152059819858&th=17989cb306d14752&view=fimg&sz=s0-l75-ft&attbid=ANGjdJ_d2FugH0RItbqplze8MOkwkwegMxAaZECWMVdUgB4Uf3S9pXHmW_1a16rJ2-xpex3HKSBGEbjPnfjlrkANT5yjEuds_jddhDwpnAqShk_f1QWHl1z2oyP-RDY&disp=emb
0?ui=2&ik=f13c396c07&attid=0.1.1&permmsgid=msg-f:1700281173780276095&th=17989cb81575237f&view=fimg&sz=s0-l75-ft&attbid=ANGjdJ_K6wp1fzkPLWC8_vWz06zviLHua2tuif61xoZtInoyVNPGq0HNaE086N7uIYETzv5lw7tamvQce7SgbfMx02TeFjnPXTLLdOfLUCpRBq97yFRpe3vmqBlKHWI&disp=emb
  • 6 months later...
How are you running the cable Outside the truck?
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
