Has anyone had any luck with buying a new 3rd brake light with camera and hooking into the system? For trucks that didn’t come with the bed camera option? Thanks!
There was a thread about relocating the camera and one about adding the system that only connects with the rearview mirror.  Are you talking about the brake light that has 2 cameras?  I have been wondering the same thing.
Yea I am looking at the brake light camera.  It was hard finding a truck with that package in my area so I just pulled the trigger thinking I could always just add one.  I have the dealer currently looking into it. I would think there must be a plug up in that outlet area and you can purchase the third brake like with camera OEM.  I was hoping the dealer could just reprogram the camera system to allow that on my touchscreen like many models already have.
Im looking into this also. Wonder if it'll be possible to add without having to add the rear view mirror also.
So far my dealer says they are unable to add that camera and sync with the factory head unit.  I guess I find that hard to believe. May have to go aftermarket on this one.  My wife is going to be pissed. lol
I am also interested in this.  I tow a fifth wheel and need a view of the bed - not the bumper hitch. I would be happy if there were a way to somehow redirect the hitch view camera to view the bed instead.
I am also researching if it is possible to add a bed camera on my 3rd break light to use for a fifth wheel trailer. I have a tailgate camera but no 3rd break light camera. Is it possible to add to the infotainment system with a 7 inch screen?
There a two ways it is done as a factory option for a bed camera. (depends on trim level)
Lower trims the view is in the mirror, higher trims the view sows up on radio screen.
UVO         Bed View Camera, camera in the CHMSL to show a view of the cargo bed, display located in rearview mirror
UVN         Bed View Camera, camera in the CHMSL to show a view of the cargo bed, display located in infotainment screen, includes Two Trailer Camera Provisions
I have never heard of this.  Does my one have the camera part number?
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 573 Guests (See full list)
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
