I have a 2017 GMC Denali 2500 HD Duramax with 72000 klms on it and the low coolant message comes up on the dash. No leaks and level is where it is suppose to be. Is it a sensor and how hard is it to change. Is it in the burp tank. Lots of complaints but no recall I take it. What is the fix here
I have seen this come up in the fall/winter, my solution is to just add some coolant to the burp tank, I usually take a cup or two and the warning goes away. This has happened only twice in 3ys and 35kmi
Did you recently have the engine block heater replaced under the recall? Apparently, to do so, they have to drain the coolant. When I had mine done two weeks ago, I drove it home with no problems. The next day, got a low coolant warning. When I called the dealer, they told me sometimes when the refill the coolant, they force feed it in and the level can be off, or something like that! They gave me a gallon to put in and I topped off the tank. No problems since.
https://gm-techlink.com/?p=9439
Proper Coolant Level on the 6.6L Duramax Diesel Engine
February 21, 2018
A Low Coolant message may be displayed on the Driver Information Center of some 2017-2018 Silverado and Sierra models equipped with the 6.6L Duramax diesel engine (RPO L5P). An inspection of the radiator surge tank may appear to show a low coolant condition.
The low coolant level in the radiator surge tank may be due to the fill process at the assembly plant, which cannot purge all of the air from the cooling system and the surge tank. After the engine has been thermally cycled, air rises and causes the coolant to become lower than when initially filled.
Coolant Levels
During a Pre-Delivery Inspection (PDI), the coolant level may appear low, but is at a level high enough to keep the Low Coolant message off.
During PDI, coolant should be added to fill the upper chamber of the radiator surge tank. (Fig. 6)
F06-c-NotFull.jpgFig. 6
A coolant level that is low enough to turn on the Low Coolant message will be below the horizontal line across the radiator surge tank. (Fig. 7) The horizontal line is a baffle inside the surge tank that keeps the coolant from sloshing inside the tank and tripping the coolant level sensor, which is located below the baffle.
F07-c-Low-with-message.jpgFig. 7
A full coolant level will show the coolant at the bottom of the radiator surge tank fill neck. (Fig. ?
F08-c-Full.jpgFig. 8
Filling the Tank
If a low coolant level is found, add one quart (0.946 liter) of Dex-Cool® coolant to the upper chamber of the coolant surge tank in order to bring the level up to the bottom of the surge tank fill neck.
TIP: The L5P diesel engine radiator surge tank has two different surge tank caps. The fill cap used to fill the system is located on top of the tank. It is a non-pressurized radiator surge tank cap with left hand threads.
The sensor is part of the tank, so if its bad you will need to replace the surge tank, then follow the proper fill procedure.
  • 4 years later...
You can still have a leak but it may not be something you can see. Lots of times the radiator will slowly be seeping coolant and it just burns off or evaporates quickly as you are driving. Usually it happens on the side tanks and you'd have to remove the radiator to see everything.
Other thing could be headgasket failure and it's slowly drinking the coolant.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,467 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
