I have a 2017 GMC Denali 2500 HD Duramax with 72000 klms on it and the low coolant message comes up on the dash. No leaks and level is where it is suppose to be. Is it a sensor and how hard is it to change. Is it in the burp tank. Lots of complaints but no recall I take it. What is the fix here
I have seen this come up in the fall/winter, my solution is to just add some coolant to the burp tank, I usually take a cup or two and the warning goes away. This has happened only twice in 3ys and 35kmi
Did you recently have the engine block heater replaced under the recall? Apparently, to do so, they have to drain the coolant. When I had mine done two weeks ago, I drove it home with no problems. The next day, got a low coolant warning. When I called the dealer, they told me sometimes when the refill the coolant, they force feed it in and the level can be off, or something like that! They gave me a gallon to put in and I topped off the tank. No problems since.
https://gm-techlink.com/?p=9439
Proper Coolant Level on the 6.6L Duramax Diesel Engine
February 21, 2018
A Low Coolant message may be displayed on the Driver Information Center of some 2017-2018 Silverado and Sierra models equipped with the 6.6L Duramax diesel engine (RPO L5P). An inspection of the radiator surge tank may appear to show a low coolant condition.
The low coolant level in the radiator surge tank may be due to the fill process at the assembly plant, which cannot purge all of the air from the cooling system and the surge tank. After the engine has been thermally cycled, air rises and causes the coolant to become lower than when initially filled.
Coolant Levels
During a Pre-Delivery Inspection (PDI), the coolant level may appear low, but is at a level high enough to keep the Low Coolant message off.
During PDI, coolant should be added to fill the upper chamber of the radiator surge tank. (Fig. 6)
F06-c-NotFull.jpgFig. 6
A coolant level that is low enough to turn on the Low Coolant message will be below the horizontal line across the radiator surge tank. (Fig. 7) The horizontal line is a baffle inside the surge tank that keeps the coolant from sloshing inside the tank and tripping the coolant level sensor, which is located below the baffle.
F07-c-Low-with-message.jpgFig. 7
A full coolant level will show the coolant at the bottom of the radiator surge tank fill neck. (Fig. ?
F08-c-Full.jpgFig. 8
Filling the Tank
If a low coolant level is found, add one quart (0.946 liter) of Dex-Cool® coolant to the upper chamber of the coolant surge tank in order to bring the level up to the bottom of the surge tank fill neck.
TIP: The L5P diesel engine radiator surge tank has two different surge tank caps. The fill cap used to fill the system is located on top of the tank. It is a non-pressurized radiator surge tank cap with left hand threads.
The sensor is part of the tank, so if its bad you will need to replace the surge tank, then follow the proper fill procedure.
  • 4 years later...
You can still have a leak but it may not be something you can see. Lots of times the radiator will slowly be seeping coolant and it just burns off or evaporates quickly as you are driving. Usually it happens on the side tanks and you'd have to remove the radiator to see everything.
Other thing could be headgasket failure and it's slowly drinking the coolant.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
