9 minutes ago, Azblktl said:
That looks awesome! Did you rattle can paint the badges? If so, which type did you use?
Thanks! I did use rattle can paint and was very impressed with the quality. I bought it from R&E paint supply. Quick shipping and very good paint. I did 2 coats of primer, 3 coats of color match paint, and 4 coats of clear.
Here are the details:
Order Summary
1 - [DUP DAP1689] Dupli-Color DAP1689, White Sandable Primer @ 5.42 USD
1 - [SMT 3680061] SprayMax 3680061, 2K Urethane Clear Coat, Aerosol @ 15.66 USD
1 - [GM WA621D] WA621D, Hudson Metallic @ 21.95 USD
Order Summary
1 - [sMT 3680061] SprayMax 3680061, 2K Urethane Clear Coat, Aerosol @ 15.66 USD
Thank you for the tips and info, going to order up some paint and get these done! Cheers!
Order Summary
How did you remove the inserts to place the custom ones? i'm trying to figure it out without messing the outer pieces up
I used a razor blade to get under it enough to lift it, then grabbed it with a needle-nose and pulled it the rest of the way off. If you do it very carefully, you can do it without scratching anything.
Razorblade damn I should have thought of that!!!
Anyone got a video or a link to how to remove the fender badge displacement inserts?  Understand they are a sticker, but want to know where to start before committing.
I found a great American flag replacement, but want to know exactly how to remove the old one before I invest in the new ones.
Most of these are to be just laid as an overlay on the stock emblem.  I had a custom set made and that is all there is to it.  If you want to remove the inlay, you have to take off the entire fender emblem to access it from the rear
    LeeBob
    LeeBob
  • Who's Online   6 Members, 1 Anonymous, 616 Guests (See full list)
