I’ve never owned a full sized Toyota truck. I’ve owned the little ones and cars. The reason I traded in often do to high mileage driving. The others were discounted more, especially GMs. If I were to buy a new truck I’d give the tundra a hard look. The main reason is no cylinder deactivation or the massive electric assist bs on the others. The few people I know who own the tundras keep them awhile, with no complaints.
We would own a 4 runner right now if they weren't so gut wrenchingly under powered. My wife and I made it a block on our test drive then turned around discusted.  She wanted a real 4x4 bad to replace her last one but ended up with a Murano.
