Guys, please help.  Every time I think  I have this figured out I actually don’t.   The dealer has replaced the door latch (that wasn’t it), they’ve replaced the passenger seat lower frame  and I’ve lubricated the hinges on the rear fold up seats and the hooks in the back of the cab.
  I’m still pretty certain though this noise is coming from the front passenger seat.  I can push on the seat when the truck is not in motion and it makes a creaky grinding sound.
I made a video clip of the noise I hear as I’m driving down any street that has imperfections in the pavement.  It’s driving my batsh*t insane crazy.
Edited by Bob Miller
My '16 did the same exact thing. I can't recall if I figured it out before I traded it.
Sent from my SM-N975U using Tapatalk
Whats odd is it won’t do it all the time.  I can drive it sometimes on the same bumpy road and it makes no noise at all.  Then out of the blue it will start ticking and rattling like a typewriter on bumps.  It’s sooooo irritating when it happens.
I can remember when it wasn't making the sound I would hit the passenger seat to try and replicate it. I remember taking the child seat apart in it's entirety looking for it. For some reason I feel as if I finally found it, I'll keep pondering if I did and maybe someone else can chime in in the meantime.
That would be great if you could remember it Brad.
I will also say the seat is real creaky when I lean on it or push it slightly.  The sound is like a creaky old mattress or something.
So today I spent a little More time looking at the passenger seat.  I took the trim pieces off the bottom  rails and then started to remove the cover off the back to try and get a better look at the inside of the back of the seat.  I sprayed some lithium grease on the rails and exposed bolts That hold the seat down and then also sprayed some on the hinges inside the seat.  After all that , the seat does still creak a bit when i move it around.  So I’m not really sure what is doing that.
I drove around a bit after all that and it seemed quieter but its so hard to tell because sometimes its quiet anyways..
After thinking for a few days, I vaguely remember one thing I fixed one the passenger seat. I can't remember if it was the tilt mechanism of the headrest or if the headrest itself wasn't seated down far enough but I remember the headrest was making a rattling sound. May be your issue as well maybe not but I'm pretty certain that was my final finding.
Hmmm, I'm going to look a little deeper into that.  Maybe try adjusting them up and down or putting some tape around the base or something.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
