I have a 2020 silverado 1500 LT z71 with a lower strut 2" leveling kit and I recently installed a 1" block myself in the back and its a little higher in the back about 1/2" so I want to get a 2.5" upper strut kit from Motofab I guess and install it myself which looks fairly easy from what I have seen but I'm not 100% sure on turning the strut 180 degrees and how hard it will be?  Is the strut hard to turn? I do not have a vice made for a strut so I was thinking when I place strut back on the truck that i could fasten the top and then try and turn it from the bottom.  Anyone done this at home with regular tools?   I asked rough country about it and they said turning the strut is simple.
Get a 0.5” rear block instead of 1.0”?
I think that would be the easiest, cheapest, and less stressful solution.
Edited by Duramax3oh
  • 4 weeks later...
Was wondering the same thing.
How hard was it to install the rear block with basic tools?
The rear block was pretty easy to install.  I bought an impact wrench but could've done it without.  The most time consuming part for me was finding a spot to jack it up where i felt comfortable getting under it on the driveway but it was sloping everywhere so I had to clear out the garage and pull in there which was in the shade anyway.
Yea I guess that would but dont want to go down lol had a hard enough time finding the 1" block so 1/2" is probably very hard
I installed the 2.5 Moto fab top mount front spacer on my 20 Sierra Crew Cab. I liked that you didn't have to disassemble and rotate  the strut 180 degrees but had a hard time getting the lower mounting tab angle from the strut twisted around to get the bolts threaded in on the first side. The angle of the tabs ends up flipped in the opposite direction after mounting the top spacer. When I did the opposite side I used a large adjustable wrench to twist the bar angle to get the bolts to align. Went together much easier when installing the strut then.
Where did you find the 1” block?
  • 1 month later...
I just installed the motofab 2.5" kit and had trouble getting the mounting flanges rotated.  I put the strut in my standard vice (protected the flange with a welding glove).  I will say that getting it to rotate in the bushing was difficult.  I actually broke my old vice.  It wouldn't lock in place any longer and rotated with the strut so I made a harbor freight run to get a new vice.  You could mount the strut at the top and rotate the flange with a really big adjustable wrench.  I actually did the first side this way after the vice broke.  It might be the best way since you can see the angle needed.  Just be careful not to bend the top mount or bolts.  I'm telling you - mine were hard to turn.  My truck has 12k miles on it so maybe a newer one would be easier.  My only trouble with the rear blocks was getting the frame lifted high enough to get the 2" gap needed to install the blocks.  Install videos make it look easy, but I don't have a frame lift like EVERYONE on youtube does.
I just purchased a 2020 Silverado 4wd Z71 LT this past weekend. I think I'm going to install the Moto Fab kit as mentioned above.  Has anyone had any trouble with the ball joints or cv axles?  I'm coming from having a Ram and a Titan and both had issues when I leveled them.  Thanks
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 840 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
