Its time for a GM truck, and i have been looking at one that seems real good to me but im not sure about how value reflects these trucks anymore. If yall could just let me know what you should be looking at price wise that would be awesome.
this is the truck im eyeing if anyone is willing to take the time to let me know if this is worth the price.0
Thank you
https://www.davis4x4.com/vehicle-details/2014-gmc-sierra-2500-hd-denali-6-6-duramax-diesel-lifted-4x4-crew-cab--short-bed-truck-ef10bce7556e384494654bf7597c0126
To me that is still too much money for a 6 year old truck with darn near 150,000 miles.
  • Thanks 1
I kinda figured that, i just didnt know if that what theyre going for and wanted to ask the guys buying them more often. Thanks man
You are paying for the mods on the one you are looking at, hard to compare a stock versus customized truck in price.
  • Thanks 1
Mods don't value to me. That is at the previous owners expense if they wish to change that stuff.
The lifted truck is just asking for more maintenance down the road. High cost for tires and suspension, more wear on all the brakes and drivetrain parts, it'll be slower, less mileage, the paint will slowly chip away on the sides and because it's the internet, I think it looks stupid.
I saw a totally rusted out Dodge about 15 years old on a lot the other day with an ask of $28 K. WWWWWWWWWWWhat?
That's 10 grand more than I paid for Pepper with a thousand three hundred on the clock. What is with people?
:idiot:
  • 4 weeks later...
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
