Eh give it an extra 50 lbs.  I was able to get things done just fine at 200-230 lbs but over that it sure got hard.
I would say age is also a factor, them joints ain't what they use to be haha... Would be nice if gm took into account repairing these things just a little bit like they use to, no engineering thought is put into that today it seems.
I had the same issue on my truck.  low coolant 4 times, once was a stuck actuator for the climate control.  They finally did narrow it down to the evaporator, but only after it was dye/pressure tested, and they used a camera to navigate to and inspect the evaporator, before they dissembled the truck.  I too was concerned, but I only noticed one trim piece not snapped on tight.  One little push, and it was in.  No rattles at all from the dash.
  • Thanks 1
For some trucks it may be a faulty condenser:
https://gm-techlink.com/?p=13599
Poor Driver’s Side A/C Performance
August 31, 2020
The air conditioning may blow warmer on the driver’s side of the vehicle on some 2019-2020 Silverado 1500 and Sierra 1500 models built at the Silao assembly plant (the plant is identified by a G in the 11th position of the VIN).
On affected vehicles, the A/C pressures will be lower than normal. For example, the low side may be 15-25 PSI (103-172 kPa) while the high side may be 140-160 PSI (965-1103 kPA). A check of the system for a low refrigerant charge should indicate that the system is full and no leaks should be found.
In addition, a temperature test of the refrigerant lines will show both the inlet and outlet lines at the condenser to be similar and very hot. The temperature across the condenser’s cooling fins will be near ambient temperature.
The cause of these conditions could be the A/C condenser internally bypassing due to a mispositioned block off plate. If the block off plate is out of position, the refrigerant does not flow through the condenser’s cooling fins. As a result, hot refrigerant entering the condenser bypasses the cooling fins and exits the condenser before the refrigerant is cooled down and returned to a liquid state.
If these conditions are found, the A/C condenser (Fig. 22) will need to be replaced. Refer to the appropriate Service Information for A/C condenser replacement.
F22-condenser.pngFig. 22
Edited by redwngr
  • Thanks 1
  • 4 weeks later...
***UPDATE***
I went ahead with the work and had the evaporator core replaced and as I said in an earlier post, I went to the shop and took a look at the progress at around the halfway mark. I was interested in seeing all components and the truck in that state (also wanted to photograph everything I could for record keeping)...well...the service department did not disappoint. Take a look!
Honestly, the interior was put back together remarkably well. I've driven the truck for a couple of weeks and wouldn't know any difference had I not gone in to see the work.
I am grateful for the job well done and happy to have COLD AC! ...also glad I didn't have to foot the bill.
shameless plug - I recently installed a Truxedo Pro x15 tonneau and am really happy with it so far...
Edited by KCU Beor
Mine goes in for the same issue Friday. Hoping for same good results as you had. I've owned around 40 vehicles in my life and this is the first time I've ever had an evaporator leak, but hey what are you going to do. The dealer/tech that works on mine has always done an awesome job. I too am a little OCD about stuff, and my heart sank a little when he told me the evaporator was leaking. I knew what had to be done to get to it. Was hoping it was the condenser, which is a much easier fix. Tech told me it would probably be about a 13-15 hour job total and that GM only pays 11 hours warranty work for it.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,255 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
