What tuner are you going to use ?
Are you going back with a stock cam ?
BTR cam. Remote tune from Klug performance using HPT
Very nice.
If you want to learn HP tuners for your self just so you can log and know what your looking at and poke around in the tune.  Go look up Goat Rope Garage and watch all his tuning 101 video's.  He is very specific to the GEN V platform.
 https://www.youtube.com/c/GoatRopeGarage/featured
Yeah I'm starting to familiarize myself with the software and have watched alot of the goat rope stuff. Still easier to pay someone, don't necessarily trust myself on a torque based ECU lol.
I was the same way at first when I got my cam.  Plus my truck is my DD so I needed it up and running ASAP once rebuild it after I stuck a lifter.  I did just a cam first then added headers, intake and wideband later once got more funds to play with the truck.  By then I learned enough to do all the changes for the new mods by flowing Goat Rope and what I learned from the HP tuner forum.  She runs great now.
On 8/26/2020 at 1:54 PM, tyler.frost92 said:
Passed 60k over the weekend. Thinking of ordering an MPVI2 through HP tuners and tinkering around. Mainly to shut off AFM, adjust fan logic, tire size, etc. Then eventually do some logs and get it tuned (local/remote). I don't necessarily trust my self adjusting more than that without seeing some examples, base tunes, etc. The logic on these ECMs seems way more complicated than standard LS stuff. Has anyone done these things in HPT and care to help? Is it worth logging with a wideband for a (at the moment) lower thermostat, intake, exhaust only setup? I look forward to eventually getting the TCM unlocked and smoothing the 8 speed out. 3ae8b7591549e6b261912bd28e9cff13.jpg
try preston moores website, he has lots of cool info , hes also got a good youtube page to get you started
On 8/26/2020 at 3:09 PM, tyler.frost92 said:
Yes adjust fan settings/logic to compliment the katech 174 tstat. My 8 speed has always seemed to run cooler than other people's, but I wouldn't be opposed to removing the trans tstat/flipping the pill
do you have grill shutters? reason i ask is , I would like to figure out how to adjust the opening closing sequence ,but i doubt HPT has access to this?
was toying with the idea of removing engine t-stat, and installing a restrictor in place, and running open, while using the shutters to regulate the radiator temp.
From what I've poked around, I've seen nothing to regulate the shutters
Been ages since I've been on here. Cam swap was completed. Drove it for about a month until it was time to park it for winter. Ran into some remote tuning issues but it was driveable. It will be getting Dyno tuned in spring to get that all ironed out. Ordered a flex fuel sensor, 20 feet of 1.75 DOM to build my radius bar/bumper/skid plate setup. Sent the TCM out to HPT for unlock, installed a pillar pod with my edge CTS monitor and AEM wideband, also in the process of getting the king's revalved for more abuse and down travel. Hoping to get deaver j1 mini packs and dirtking shackles and hangers ordered soon as well. Needless to say I'm ready for warmer weather so I can start wrenching again [emoji28].
Should add a flex fuel sensor and tune for E85 as well.
Lol I said in my post that I ordered a flex fuel sensor and am getting it retuned.
Was talking with Lew and Diablew tuning about the shutters, there is no access to this within the ECM.
Even with my 174, I still see ECT in the 190s consistently due to a lack of airflow across the radiator.
From what I gather (AC compressor OFF), the shutters will open when slowing / almost stopped. Remain open when stopped and at speeds up to high 20s and then close at about 30mph and stay closed thereafter.
I'll probably just trick the grill shutter motor and remove the vanes.
i've posted this question about shutter tuning on the HPT forum, yet no one has said anything about it in  over a week. I might have to give tech support a ring and see what they have to say.  i really like the idea of the shutters for dialing in the ect temp. a 175 t-stat operates at about 165 F on the highway, a bit too cold  but i'm not having any issues from this. so who cares then!
Edited by flyingfool
I live in AZ, morning drives to work place me in the 30s and I'm seeing low/mid 180s.
With amb temps warmer in the afternoon, seeing low/mid 190s.
I think where the most benefit will come is during the AZ summer. I noticed that when I cycle the HVAC on (engage compressor) the grill shutters started to open when at speeds above 30mph. Meaning, in the summer the compressor loads going to be high and I expect my shutters to be controlled open majority or the time. If this turns out to not be the case, that's when I'll work on tricking the vane motor. Otherwise, dont really see much need for the effort yet.
    DM22
    DM22
  • Who's Online   5 Members, 1 Anonymous, 2,064 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
