2000 silverado 4.8L. Brake lines rusted out. Vehicle sat for a few months with the lines cut from the abs pump. I lost all fluid. ABS fuse was pulled. Fast forward to the repair... I replaced lines and tried to bleed the traditional way and got nothing although I had pumped about a quart into the system.
My MC was corroded and old and I figured that was part of the problem so I replaced it before resorting to towing it into a shop.
Afterward I was able to bleed the brakes at all 4 corners with the 2 man method. Most of the air seemed to escape from furthest rear. I used another quart or so when bleeding.  I then reinstalled the ABS fuse (no lights now on dash). Brakes seemed a little soft after doing it but I went on a gravel road and made some hard stops and it seemed to tighten it up afterward. I did not bleed the system again.
So my question:
Is it impossible that my brakes are bleed correctly as they stand now?
I ask because I read the warning about needing a scan tool to bleed the ABS to be able to get anything from the calipers at all.  I am confused as it seems satisfactory now.
Thanks for the reply. Im second guessing myself after reading all the posts about the abs module needing the scanner.
I also read about cycling the abs on a gravel road which i tried to do. However i am unclear exactly how the abs and truck should respond in such a case. The truck just came to a stop, no skidding... the pedal was softer than it was when i was normally stopping on pavement.  Also no abs light came on like i thought it might if i activated the system.
Edited by xrmik
So my question:
You also have to bleed the ABS system and that is done with a Tech-2 or equivalent.  Replacing all of my calipers and draining the old fluid out, I went through 6 quarts of brake fluid after doing the traditional and ABS bleeds.
I bled it a second time, after doing the hard stops on gravel and the pedal seems great. In fact it a noticeable difference than how its been the last year or two with the rusted out lines and corroded master cylinder.
If there was still air in the pump, would it be immediately apparent by pedal feel?
Edited by xrmik
I don't know the answer to that one.  @CamGTP
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
