My 2016 GMC Sierra SLT 1500 has a clunking noise coming from rear of truck when turning in or out of my driveway or when making a turn onto an uneven surface,,,can anybody advise me as to where this could be coming from and how to fix it,,Thanks,,
Kinda sounds like whats going with mine. Usually does this with frame twisting. In my case my leaf springs are rotating right or left and the keeper on the front is a bit out of shape. Not sure if the leaf pack is shot. I'm trying to find time to have the dealer check it out. I'll let you know what I come up with.
One thing I did notice yesterday was a heavy load in the bed quieted it right up. Food for thought.
Sent from my SM-N975U using Tapatalk
Sounds like the locker differential, try jacking the rear tires off the ground SECURE WITH JACK STANDS!, start and place in drive, with your foot, try to slow one of the rear tires down, it should slow down to the point that the locker "Kicks in", if you can't slow one of the tires down, then the clutches are lock up some how.
I have the same problem in my 2018 Silerado 4WD. Most noticeable when there is a load in the bed or when towing (tongue weight about 400#) It is currently at the dealer for the third time. Last visit they removed the bed to isolate that. Any ideas or solutions much appreciated.
mine did this too...i found it was the leaf springs ....i used a can of white grease and sprayed it right behind the front perch where the clamp is ....use a can with a straw so u can get it in there good ...any lube will work...maybe give it a try and see if that is your trouble
Edited by evad
Try some bicycle inner tube over the spring pads. That quieted mine down. It has been over a year since I did that and it is still quiet. I cut a bicycle inner tube into four equal lengths. Folded each length over itself and put the folded end over the pad and used a tie wrap to hold in place. I placed a length of folded inner tube over the front and rear spring pads and this has stopped the clunking sound from the rear of my truck.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
