Can someone tell me if these control arm bushing is serviceable.
Truck goes into the dealership Thursday for oil pan gasket leaking.
My used truck undercariage is rusty. Truck was purchase in Georgia.
2016 Sierra 77k miles 4x4.
Thank you.12bbacc3b0fb6dfc31dc4ef2e41a1a0b.jpgba0bb8d5abcc1933bc90256c42911709.jpg427b79e8dc203cd09c2b27596568f1d0.jpg8db976a120dbc469c6cb898f611eb63f.jpgc2ed9e3bc850ea5200d155a5764516de.jpg578553915e2e645104009b78537d54cc.jpg
Sent from my SM-N976V using Tapatalk
Truck is at the dealership now .
I guess my faith is in the hands of the mechanic.
Service-able. Absolutely. Now finding someone will to do it instead of the quicker A arm replacement is another story. They like to do what is quickest and easiest for them. $$$$ The R & R of the A arm as a unit MAY be cheaper than that of the bushings but yes, it can be done and parts are available.
It's more effective to change the arm. It takes a lot of force to push the bushings in and out. You could probably make a jig of some type to do it, but what's your time worth?
Sent from my SM-A516U using Tapatalk
I'm tracking now.
Appreciate the help
1 hour ago, MY164X4 said:
I'm tracking now.
Appreciate the help
:D
