I tried doing the thermostat flip but couldn't get it out, the c clip came out ok but there was some corrosion stopping the guts coming out. Want to buy a new complete replacement with the block to swap out but can't seem to find the part listed.
Anyone have a parts diagram? Can only find lists on the parts sites.
Sent from my SM-A705W using Tapatalk
Take you VIN to the dealership and he will order the correct part.
Was hoping to avoid that as it's a 45 minute drive to dealership so if I can't do any other way I guess it will have to wait for another couple of weeks.
I had the same issue when I did the "flip" on mine. Remove it from the truck, spray some penetration fluid on the C-Clip area, remove the C-clip & take pliers & twist the aluminum top using the standing boss on tip. It will come loose & out. Before assembling, clean top & housing block with some Scotch Brite, run the C-Clip over some fine sand paper to remove any corrosion or just replace it. Put it back together BUT make sure the C-clip goes back into the groove all the way. If you don't , others have had it pop back out. Spin the C-Clip in the home position to verify it's in the groove good. Then reinstall on the transmission.
Here's a link to what I found for P/N https://www.gmpartsnow.com/oem-parts/gm-tube-assembly-84036742?c=Zz1jb29saW5nLXN5c3RlbSZzPXRyYW5zLW9pbC1jb29sZXImbD0xJm49QXNzZW1ibGllcyBQYWdlJmE9Y2hldnJvbGV0Jm89c2lsdmVyYWRvLTE1MDAmeT0yMDE3JnQ9bHR6JmU9NS0zbC12OC1nYXM%3D
If the OP destroys the original trying to "fix" it he'll really be without a paddle. (or a truck for that matter too.)
This is what I bought for my 2019 Tahoe 6L80. I wanted to have two on hand just in case, so I wouldn't have the vehicle out of commission. My personal recommendation would be to do the thermostat exchange on a "cold" vehicle, so first thing in the morning after sitting overnight. This is just my paranoid self, I would rather work on materials and deal with tightening/torque specs at amb vs elevated temps.
By-Pass Valve – 48.76 -
13511136
6 speed.
https://www.gmpartsdirect.com/oem-parts/gm-by-pass-valve-13511136/?c=Zz1jb29saW5nLXN5c3RlbSZzPXRyYW5zLW9pbC1jb29sZXImaT1HQzE1MTE1NSZyPTMmYT1jaGV2cm9sZXQmbz10YWhvZSZ5PTIwMTkmdD1sdCZlPTUtM2wtdjgtZmxleA%3D%3D
Found it on Ebay from a local vendor for under $35 IIRC
Edited by 14burrito
This statement is true for any owner making this modification and only proceed depending on their confidence level & tools available to them. I wouldn't recommend it to a novice that does NOT have the tools or confidence to preform this modification. All I was doing was sharing a similar situation that I experienced hoping that iy would help him. If he wants to buy a spare back up set, that's surly his option. That's why I gave a link for the part that I thought he was searching for.
Thanks for the info. I did soak it with penetrating fluid but didn't have the time to leave soaking for a few hours so would rather have the spare & yes the c clip was a bugger to get seated properly.
Now I know what the parts site calls it 'bypass valve' so that should help with sourcing, thanks very much.
Understood. I found when I did mine that there is more than one depending on year and VIN. The hoses attach by a few different means. Mine didn't use clips but a plate and bolt setup. VIN is important. A random part number may not work. That was/is my concern.
Depends on how the lines are attached to the thermostat.  When you removed the thermostat, did the lines un-bolt from it with a plate holding them down?  Or were the lines quick connected into the thermostat?
Edited by newdude
Ok, thanks very much for the feedback.
Just double replying.  Not sure if you saw my other post but I've got the ? again here as well.
Quote
1 hour ago, Mozzer said:
Here's what I've got.
That's the quick connect style. My part number will help eliminate a choice. This number is for the plate and bolt style my truck has: GM 13511136 The other GM number is then yours. Hope that makes sense.
Great thank you very much.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
