I lost the brakes on my  250K  02 Sierra yesterday.  The ABS  braking has been acting up the last 4-5 days  during  say... 1 out of  6 normal stops. Doing the typical GM moaning  and groaning it does if it's slippy out  or the rd is  very bumpy at a stop sign BS.  Doing that under normal conditions though.  I couldn't make it do this when I tried several times, so not sure why that is.  My reservoir is  1/4 " low of fill line, and I don't suspect  that's related to this  there's  no seeps or leaks I can see under the hood or under the truck anywhere.  I pulled the ABS fuse and the only difference was it made the ABS and brake lights come on. When replaced they went out. I replaced the ABS module with a used (140K ) unit 10 months ago chasing another issue.  They're so weak I just ran over the top of my car ramps because they wouldn't hold even creeping.   Anyone had these issues?
It's unlikely to be the abs module, as it's designed to not significantly affect braking, even if it fails.
More likely, given that you say there is no leaks and the brake fluid isn't going down, that your master cylinder has failed.
I would also suggest examining the brake lines, as depending on where you live, the lines are known for rusting, particularly the 4 lines running along the frame from the driver's side front wheel to the abs controller, and also the rear line running along the frame above the fuel tank (hard to see without an inspection camera).
The moaning is abs activation,one or both front wheel sensors is dirty,get the truck on the proper scanner and see where the fault is
No leaks seen under hood or truck on drivers side frame rail . I had a  hard line replaced there last yr along with all the bleeders and a pass side ABS sensor.
With the truck running...  The pedal goes to floor feeling like mush the last inch.  With truck off it feels like it "pumps up" a bit with more resistance, but still goes to the floor.  I started the truck after pumping them this way, and they still won't hold the truck in gear past idle.
Well I was wrong. It was a leak! A line burst on the outside of driver frame rail.  My buddy tried to patch it with a compression fitting, and had to pry it from the clip on the frame to do it. Well... once together that line burst again where the factory bend goes over the rail. Perhaps prying it out made another weak spot .  Fixed with a new piece of line from ABS unit to union of existing line. Now I can't get the front brakes to bleed. Just a bubble, or dribble. Been around the truck  6 ? times, and still nothing.  Parked it on a steep incline looking for some help from gravity, but no dice.
From what I've gathered it could be the ABS unit that now needs bled to get the air outta it.  A special scanner is used to remove air from the unit into the lines so it can be bled what I've seen, and rebleed, repeat.  But , I saw a video of a guy breaking the lines loose on the unit itself to bleed.   Anyone been there?
this is kinda farm boy tech but don't mess with the abs unit,,fill up the master cylinder crack all the bleeders and let it sit overnight then try again ..if no luck go get a new master cylinder
The abs controller can hold a small amount of air in it, which is what more advanced scanners/computers enable you to bleed out, but it won't alllow air to be drawn into the lines, other than the fittings not being clean and properly tightened to it.
Overall the bleeding process is:
a) bleed all 4 corners, starting with the wheel furthest from the MC to the wheel closed to the MC
b) perform the abs controller purge procedure (requires a more advanced scanner/computer to do this)
c) bleed all 4 corners again, in the same order.
At the end of a), all 4 corners should have shown no air in the lines.  If they continue to have air bubbles, something is wrong, from lines not being connected/tightened properly, to using a vacuum bleeder having too much vacuum and drawing air through the threads of the bleeder screw.
And some people will do a "redneck" method to get the air out of the abs system, which is to (after doing step A) go to a dirt road and then do multiple panic stops to activate the abs system each time.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
    • Engines wear. It is unavoidable. So the question isn't if it will wear out but rather WHEN it will wear out. That question is about rate and RATE is a HUGE problem for almost everyone; but not in the way we may think.    Unless there is something drastically wrong with your powertrain, wear is exceedingly slow. It doesn't wear out in minutes or hours or days or months but in years or even decades. Ditto sludge and varnish. Humans are an impatient lot so to see the benefit of a truly superior product you may have to wait a very long time. Most will get bored first and trade before they reap the benefit.   Humans are not companionate creatures when it comes to those we do not know. We don't care what happens to the second or third owner as long as it doesn't happen to us or someone we know and actually like.   Sad commentary on humans but it is what it is. That thus, then, there is no advantage...to or for you if the above paragraphs adequately describe you.    BUT if you are a buy and hold type and patient enough to reap the rewards of your labors then that thing that is happening that you haven't yet seen, but will; can be abated by such products. Seals harden and leak with time and lots of it. Rings stick after thousands of miles of a slowly building plaque of varnish.    Then there is this. This didn't happen over night and this poor fellow knew when he removed the cover and not one second before.   Not "aware' isn't the same thing as "isn't happening".        The above was typical of the Ford 361 and 391 bus motors on Bulk Pennzoil Mineral Oil products on 3K mile OCI's at about 60K miles back in the 60's and 70's at the Anamosa School District when my Uncle took over their maintenance program.    This is Pepper at @ 165K on 5K OCI's using Group IV/V Full Synthetics.      HM oils will help the first but not the second.    Then again if one used..... ah, ya know.....
    • Thanks for coming back with an update.
    • Awesome you got it sorted! That's a new potential issue I'll have to mark in my book of issues. Thanks for the feedback.
