My passenger mirror has started  moving on its own. Truck has 29K miles on it. No factory warranty. I do have an extended warranty but I just used it yesterday to have a check Engine light fixed O2 sensor)  and the horn replaced. Today I am driving along and the mirror just goes all the way up and out. I move it back and it stays fine but when I start the truck it goes to the extreme range again. Tried resetting the seat preset and turning off the curb assist.
Any idea what's causing it. I really hate to bring it back in to the dealer for this. I fold the mirrors regularly ( power fold) and that works fine. I am wonder if its a faulty/dirty connector or something.
Is it moving while you’re driving?
Yes it's done while driving.
7 hours ago, AdioSS said:
Maybe a bad ground?
Thats what I was thinking.  The truck has had a few electrical gremlins. I'll check the connections and see if I can fix it. I really don't want to replace the mirror.
if all the mirror functions work with the door switch, then you dont have a wiring problem. something is sending a signal to tell the mirror to do this, faulty door switch or memory module is having a brain fart. try disconnecting the battery and then reset the seat memory and mirrors
I was thinking the memory recall here. Does it seem like it moves to the same position each times it moves? If you take your other key fob and unlock your door, does it move the mirror to the same position as you describe? It does it seem like a random movement?
That was going to be my next step. Everytime I turn the key on it tilts all the way up.  I have tried resetting the program but still does it.
I haven't tried the other key but I will thanks.
So second key made no difference I was going to disconnect both batteries  and see if that reset things. I tried resetting the program a few more times. Then it started going all the way down instead of up. Reset it again and it moved less down then reset again and it seems to say put. So I don't know what the issue is. I'll keep an eye on it and see if it starts doing it again. It seems like the mirror lost its point of reference.
Were you able to find anything new on this?  I have the same problem with my 2020 Silverado 2500.  Dealer has tried numerous times to diagnose/repair it, but no luck.  They most recently replaced the memory module but that hasn't worked either.
Sounds like something is shorting and trigger a command to make the movements. Just not sure what/where to look.
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
