Good Morning, I wanted to see if anyone has knowledge of the knock sensors in the 2004 GMC Sierra 1500 5.3 models and what they affect when failing? My light started coming on last week and the mechanic says the intake has to be removed to get to the sensors. Just want to know how serous an issue this is to be corrected.
Thanks
Heath
It will still run forever with the knock sensor codes but it will be down on power. Any time a knock sensor code is present the computer will remove ignition timing thus removing power from the engine.
Knock sensor failures are very common on those trucks.
I'm looking for part numbers for gm  knock sensor and wiring harness....If anyone has information on these please let me know.
Rockauto is always a good source for research. Also 1aauto
AC DELCO
Knock sensor 2133521  is what I used on my 2004
Harness 12601822
Confirm these parts yourself. Watch out for counterfeit parts when purchasing
Edited by txab
I have the knock sensor gm part number- 12589867
the model truck I have is a 2004 gmc sierra 5.3 L
The number post above and these following numbers are all the same sensor.
Alternate/OEM Part Number(s): 10456603, 12589867, 213362.
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, they can remotely disable the device. B) Make sure it's paid off. If they still owe money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
