I found a guide to drop the unit and will be digging into this next week.  Has anyone tried pulling this unit apart yet?
My goal?
Adjust the beam closer to my lap instead of the door
Edited by Rob Mugs
Not bright enough to mess with. I bought some LED rock lights, found the hot wire, mounted 2 to bottom of console. WAY BRIGHT. I think 1 would work. They turn on and off with map lights.
Edited by Arboc
spelling
It's sad but I wish the OEM lights had replaceable bulbs.  My 2020 is better than my 2015 was, but still not bright.   In all of my wife's Hondas' I've pulled the 194 bulbs and replace them with a flat panel of 18 LEDs.  It's like daylight the moment you unlock the doors.    I'd love to do it to my truck, but I might just install some lights in the foot well area.
14 hours ago, Javier121 said:
Where did you tap light to make them work in conjuction with dome lights what wire on that top light is best to tap into?
Here's a thread that might give you some additional information.
Search for Interior lighting on this forum. It will involve a lot of reading but it will be worth it. You can install Oznium LEDs up in the overhead console.
Copy. Bought two of them but got apprehensive if I wanted to see two yellow eyeballs looking at me when they aren’t on…………
Seriously considering another light assembly about the middle but not wanting a hole in the headliner for the wiring is stopping me on that one. May see if I can add an LED light just rearward of the console. Like right next to it….
Went ahead with two in the upper console….
BEFORE
IMG_0605.jpeg.c6993f25b62a8222788227031a2554e5.jpegIMG_0603.jpeg.1046d281cd5a314cbbd1c4fe1344a3dd.jpeg
Nothing new but two LEDS really help…
Edited by DHBWA
BEFORE
how did you add them?
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
