Timewas Posted November 13, 2020 Posted November 13, 2020 2003 Silverado extended cab 4.8. Engine cranks when Inserting the starter relay,if the key is on it will start but the starter continues to engage until I pull the relay out, engine then continues to run fine
davester Posted November 13, 2020 Posted November 13, 2020 Could be the ignition switch, or perhaps the relay is bad.
Timewas Posted November 13, 2020 Author Posted November 13, 2020 Thanks Sorry I should have mentioned that was my thoughts on it so I installed new ignition and relay still the same problem..
Ian Mills Posted November 13, 2020 Posted November 13, 2020 So, just to clarify: Does the starter always crank if the relay is in or is it only when the key is in run/start?
riverbanks Posted November 13, 2020 Posted November 13, 2020 Yikes,is there a remote start on it?if so, disconnect it
Timewas Posted November 13, 2020 Author Posted November 13, 2020 No remote start no automatic anything just a stock 2003 Silverado 1500 extended cab auto trans 2 wd
Ian Mills Posted November 13, 2020 Posted November 13, 2020 46 minutes ago, Timewas said: Only when the key is in run/start My guess is a bad starter solenoid. Have you ruled that out?
Timewas Posted November 13, 2020 Author Posted November 13, 2020 Did I forget to mention that it won't start with the key at all?? The problem started with what seemed to be the starter relay being bad, it would refuse to start via the key then I would take the relay out and reinsert it and it would start with the key in a normal manner, then it stopped doing that and I had to run a hot wire to the 87 leg on the relay... then is started doing this ...I installed a new ignition switch but nothing changed
riverbanks Posted November 14, 2020 Posted November 14, 2020 Sounds like relay center has corrosion,how does the relay receptacle look? remove your wire and check for power at 30 on relay,and go to search,2003 Silverado No pcm ground to starter relay,in"ask the technician"forum
riverbanks Posted November 14, 2020 Posted November 14, 2020 Slow internet 2003 Silverado No pcm ground to starter relay - Ask the GM Technician - GM-Trucks.com
Timewas Posted November 14, 2020 Author Posted November 14, 2020 Thanks but apparently that file is not compatible with my version of windows
riverbanks Posted November 14, 2020 Posted November 14, 2020 Figures,my phone is old,but you can find that thread
txab Posted November 14, 2020 Posted November 14, 2020 (edited) I assume this is the thread you were trying to post. Edited November 14, 2020 by txab
sefiroxx Posted November 15, 2020 Posted November 15, 2020 Yes, corrosion or short. You'll net a meter to back trace to see where the relay signal wire is getting it's 12v from and to check the relay main legs to see if it shorted close.Try shaking the harness under the relay/fuse box to see if that changes behavior. Then do the same with harness up to the steering column.
