Guys/Gals,
I have no clue about rims.  All I know is I am done with 20's rims and want to go back to 18's has anybody bought rims from Costco?  Looking for 250.00 per rim easy to clean don't understand all the Offset and other nonsense.
Thanks...shoot me some ideas!
Guys/Gals,
I sold my factory 20”s on craigs and picked up a set of 18” AT4 wheels off of a 2020.
FYI any oem GM 6 lug wheel 2007 - 2021 off a full size suburban, Yukon, Tahoe, Silverado, Sierra, Escalade will fit your K2xx. Must be 17” or larger wheel to clear the front brake calipers. Factory spare is a 17”.
Don’t have to worry about offsets when using a factory wheel.
Colorado canyon wheels will not fit as they changed the bolt pattern.
Thanks, I checked it out and those rims are all about the price I wanted to pay until shipping?  I went Costco don't even know what they really look like but hey...I don't care 18's with more tire is going to feel good!
best offroad rims from GM are for the police PPV Tahoe, those are 17" and wider that the Work truck rim, they are powder coated  gloss black
but its far cheaper to pick up a low milage new set off Craigslist from the Z71, Tahoe , AT4, or RST or trail boss in 18", usually they are balanced and have wheel sensors installed for $650-700
the !8" rims wont get curb rash either, my main reason for switching, plus the truck handles so much better now
Edited by flyingfool
Check craigslist for take offs.  Dealers often sell them (cheap!) when customers buy bigger wheel and tire packages.  Around here, I can often find a set of take offs (rims and tires) for cheaper than just new tires.  I guess the dealers just don't want them taking up space, and they can't go back into general inventory as they're 'used.'  Needless to say, they go quick.
Someone correct me if I'm wrong, but the 2019 and newer tire sensors won't work with older trucks.
On 11/16/2020 at 9:52 AM, mookdoc6 said:
Guys/Gals,
Offset Mook, is the distance, in mm, from the center of the wheel the axle side of the wheel is from centered. Positive offset moves the wheel closer to the frame and negative then to the outside. The factory steel 17 inch rim which is 8" wide has a 35 mm positive offset. The alloy spare which is 7-1/2" wide has a 31 mm positive offset. This may be useful to you:
https://tiresize.com/wheel-offset-calculator/
It will help visualize your wheel tire options.
  • Thanks 1
Thanks, yeah it helps I don't need anything sticking out from the fender to make me feel bigger in the britches.  I really have no idea what I bought and we shall see what happens?  I know the 20's have bothered me since I purchased with the harsh ride.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
