Hey folks,
Looking to see what you guys are using for hitch reducers/clamps to go down to a 2"
I run a Kuat NV 2" bike rack w/ anti wobble hitch cam but with the sleeve it wobbles too much for my liking carrying $12K worth of bikes.
One of my buddies suggested buying a longer 2" sleeve and having it welded from the spare tire side of the hitch, but not sure if I want to do something that permanent yet.
Thanks!
If you weld the adapter to the bike rack that will remove half the slop.  Then maybe run some weld beads on the OD of that with some grinding so that fits snug in the 2.5 inch receiver.
Hey folks,
Thanks!
You can drill and tap the outside receiver for a 1/2” bolt and lock nut. It puts pressure on the inside reducer so there’s no play. I did this with my past two trucks. 511ce272afe191c1808d7c060a116982.jpg
I don’t remember how the Kuat NV wedge system works but here is a picture of the adapter that 1-UP makes and it works great for me.
I switched to 1-UP years ago because I was one of the coaches on my daughter’s NICA team and I needed to carry 6 bikes sometimes (two of the 1-UP racks on the tonneau cover and a 4 place in the hitch).
This adapter has worked well in my 2016 and 2020.
If you need the pin to go all the way through you may need to drill an additional hole as CPAP did above...
  • 5 months later...
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
