Make sure you use diesel oil. The circle should say ci. Compression ignition. If it only says si, spark ignition, it's not diesel oil.
Sent from my SM-T510 using Tapatalk
FWIW, the 2.8L, the 3.9L and the 6.6L Dmax engines all use different oil specifications...
For the 6.6L:
Engine oils with the letters CJ-4 or CK-4 are required for your vehicle.
The CJ-4 or CK-4 designation can appear either alone or in combination with other American Petroleum Institute (API) designations, such as
API CJ-4/SL. These letters show API levels of quality.
To determine the preferred viscosity for your vehicle's diesel engine, see Engine Oil pg 90.
Viscosity Grade
Use SAE 15W-40 viscosity grade engine oil.
When it is very cold, below −18 °C (0 °F), use SAE 5W-40 to improve cold starting.
The additive package in oils for gasoline engines is different than for the diesels.
If it was my truck, I'd change the oil sooner, rather than later.
Hey Redwngr,
Been waiting for your post. That was the plan to change the oil out. I haven't driven since the post. Planning on picking up 10 Qts full synthetic today - Mobil One 5W-40 for diesel with CJ-4
Thanks,
Scott
