I recently purchased a used 2019 CCSB Duramax 4wd with 70,000 miles.  I pulled my 24 foot enclosed bumper pull cargo trailer on a 1460 round trip through Kansas, Oklahoma, and Texas.
On the way out the total weight of the trailer and cargo was approximately 8500 lbs and on the way back it weighed approximately 6900 lbs.
On the way out averaged 7.9 mpg and on the way back averaged 7 mpg.  On the last 200 miles back there was a considerable head wind and I only got 6 mpg.
The only modification I am aware of is the previous owner installed 275/70R18 tires in place of the stock 265/70R18.  The difference in tire size is about .5” in diameter and 1.5” in circumference, not a significant difference.
Do these fuel economy numbers seem low?
I was getting about 6mpg pulling similar loads with my 2015 1500 with a 5.3.  I was hoping to get at least 10-11 mpg while towing these types of loads.  Were my expectations too high?
With my long gone 2015 GMC Sierra 2500 with an LML the 10 to 12 miles per gallon towing a 37-ft travel trailer was very common only occasionally did I drop down to 9.  Biggest impact for me was regeneration of the DPF.  Small things like electric brakes dragging a little bit or poor aerodynamics on the trailer or even excessive speed on your part could dramatically increase your fuel consumption.
Anything over 65mph is going to start tanking fuel mileage. You are towing a massive brick afterall.
I agree with you that faster speed will decrease fuel economy due to air resistance. I’ve pulled similar loads with similar aerodynamics with my previous 5.3L 1500 and got 6 mpg.  I just want to make sure my truck isn’t consuming excess fuel for some reason that could be addressed.
Next time you need to tow that trailer do your own MPG loop. Even if it's only like 50 or 100 miles total. Drop your speed to 60-65 to see how big of a difference it makes.
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
