Did a few searches but seeing if anyone knew of any companies that offer a full front/rear coilover lift for the ‘21 2500 AT4. Just got my truck back from the dealership and am looking to buy one ASAP. Thank you.
Check out Kelderman lift kits. That might be the closest thing you'll get. They offer some type of 4-link rear end set up that you might could do coilovers on, but i'm honestly not 100% sure.  Oh and they are 10-12k for their kit if I remember correctly. Other than that, i think you're probably gonna be out of luck.
i dont think ben sells the coilover conversion kit 2500s only the shocks.....you need some welding done and a bracket but the rear isnt coilover anyways it has leaf springs......with enough money am sure its possible
BDS sells a coilver kit for front and am sure KING has a kit as well......you need upper and lower control arms and a shock tower welded on and obviously the shocks......they are supposed to ride pretty sweet but yeah expensive
deaver makes spring kit for rear to smooth it out a bit
  • 10 months later...
  • 3 months later...
