So, silly question.  How do I know if I have a power-down tailgate?   Because it just unlocks when I push the button, doesn’t go down, so I am suspecting I don’t.
2019 TB.  Build sheet says “Tailgate with lift assist and power lock.”
Build sheet should read RPO Code: QT5 - EASY LIFT, POWER LOCK AND RELEASE TAILGATE.
i hope someone creates a after market manual tailgate latch for these trucks. I open mine 100 times or more a day sometimes. Its only a matter of time..
maybe its time to fire up Fusion and the 3d printer ...
I think all of them that have the button has power assist. i know mine does and its a lower Trim Level WT Truck. I do like the power down feature . but as said above , Just like the power door locks on my Work Van  locked and unlocked  all day long at times ( lots of expensive stuff and sometimes in sketchy parts of town)  wear out quite quickly.
I"m happy to report I finally got the updated actuator, and it took care of my issue.  I really wish I had joined here earlier as it would have saved me a lot of money and headaches.
Thanks to everyone for all the help.
  • 2 years later...
My 2019 Silverado tailgate would not open without pushing button many times. After getting it open I pushed the locks into locking position on both sides with my finger and could see the right side not unlocking when pressing the button on my key fob. It would take 3-7 attempts before unlocking. I then removed the back panel off of the tailgate to check the actuator and noticed the right side rod that goes out from actuator was more loose than left side. I removed it carefully and took a pair of pliers and bent in the 90 degree bends an both ends of the rod just a little more and replaced it back into it's mechanisms and put the the small latches back on. It did the trick. Opens on first try every time now. I guess over time those rods just get a little loose or the holder gets worn.
Edited by RA from MS
mispelled
Crank the truck, see if inner gate open warning is on.  If it is, hit the inner gate button and keep slamming it until the warning is off.  A tailgate shouldn’t be this difficult to design.
Somehow the tailgate will not operate if that warning is on.
Edited by deadon2
@lothodon any chance you have the part number for the updated actuator, or is the one that was shared previously in the thread what I should look for? A quick Google search of that part number comes up with a few different options.
I’m having the same issue with my 2019 Trail Boss.
Edited by Mithrandir
Pickup Box Tailgate Lock Actuator - GM (84873070)
This is the updated actuator that was posted previously by @lothodon.  This number came straight from the GM service bulletin that was attached in an earlier thread.  I also have been fighting this issue with my 2019 silverado RST since day 1.  A year ago I brought it to the dealer and they replaced the wiring harness for the tailgate, but the issue is back and I also am going to try the new and improved actuator.  No surprise, chevy still can not make a working tailgate latch.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
