Hey All,
Another leveling post, I apologize.  I've been looking for samples of anyone who's put on a 3-3.5" leveling kit, as well as bigger tires.  Thinking 285/65 20's.  Also looking at 1.5" wheel spacers and coming from a Ford, I know how that looks, but I'm struggling to find an example of how it'd look on a Sierra, which will be my next truck.
Thanks.
Edited by ekraft84
Here is my 2020 AT4 with BDS 2.5" coilover lift kit.  I would recommend you consider a lift kit (even if you don't go to the expense of new shocks) over a leveling kit to get proper geometry on your cv axels.  If you start at 2" with OEM AT4/Trail Boss lift - then ad 2-3.5" - you end up with pretty extreme angles and wear an tear will occur.  You can spend and extra $500 - $700 up front for proper lift and get good CV angles, or pay the piper down the road.  I had a 2019 AT4 with Ready Lift SST 2" level kit - picture below of CV axel angle - it i not ideal - RL states on site that they do not recommend using "auto 4WD" with level kit due to torque on the front diff from poor axel angels when shifting on the fly at speed.   Rough Country, Zone and BDS all offer proper lift kits that lower the front diff to proper geometry angles in the $1,000 - $1,500 range.  Level kits are $400 - $700 - so you get to decide.  If not dong much off road or using 4WD much - then level will likely be fine, but if off roading or using auto 4WD - buyer beware
2020 AT4 with BDS 2.5" lift with Coilovers
2020 AT4 with 2.5" BDS lift CV Axel - pretty much dead level
2019 AT4 with Ready Lift SST Kit 2" level kit - pretty extreve CV Angels - RL states - "do not use with auto 4WD"
Edited by Supercup
Thanks Supercup.  Truck looks sharp.  What size tires are those?
I was looking at the Autospring leveling kit, which would level & raise the front and rear, keeping the angles in check, as far as I can tell.  I would like the rear just slightly higher than the front, ideally.
Mine is still on stock 275/65/18 Duratracs - will go to 285 or 295 when these are done.
Here is photo of my 2019 with RS SST level kit without their rear block and stock wheels - then with their rear block (about 1/2" taller than stock), with Method wheels for reference.
1195288232_DP1.thumb.JPG.0c75d35792b45a1ec4d5cde5206dfad4.JPG1267978408_DP3.thumb.JPG.b049c0bdb882d51de6bcd063e328789e.JPG
Thanks again for the photo.  I'm thinking with stock wheels, wheel spacers will be necessary (based on preference, looking at others on the road).
I'm thinking of putting 285/60 20's on, with 1.25"-1-5" wheel spacers - and bumping up the leveling blocks another inch or so (in addition to the 2" the AT4 comes with) on both the front and rear.  I'm hoping that would give a nice, slightly more aggressive look.
Whatcha think?  :D
Edited by ekraft84
I'm installing the 1.75" zone leveling kit with control arms on my trail boss Wednesday. If your gonna do a leveling kit spend the little bit extra and get the one that comes control arms. Tire size wise I'm putting 285/75r18 maxxis razr mts. Can't comment on the wheel spacers because I personally just don't like messing with them. Lift wise I'll be right under 4" from a standard silverado or gmc.
Awesome setup. I'm assuming that kit can work on TB as well? Do you by chance have the link for the parts you purchased? I was also looking at the RL 2" SST kit but you setup looks solid.
Hi,
I had RL 2" SST on my 2019 - you can't use "auto 4wd" with that level kit.  CV axel angels are pretty extreme (see photos below).  With proper lift you spend more, you get level cv axel angles and the upgraded shock offer good ride and a lot of upgraded performance, especially offroad - but you do pay for that.  Zone (owned by BDS) offers a lift with no shocks - that is a good option if the shocks are too expensive - but add them later.  Only give up is when you drop the diff - you do give up some front ground clearance - stock is 10" - BDS to bottom of diff skid plate is a about 8.1" - so bigger tires are nice, if doing serious off road work.
If you decide to go with RL SST kit - cheapest place I found it was Tire Rack - $586 (was $512 when I got for my 2019).
LInk: https://www.tirerack.com/suspension/suspension.jsp?make=ReadyLIFT&model=SST+Lift+Kit&autoMake=GMC&autoModel=Sierra+1500+4WD&autoYear=2019&autoModClar=Crew+Cab
The kits are the same for AT4 and Trail Boss.   BDS has multiple options and Zone has level and lift option.
Link BDS:  https://bds-suspension.com/product?kid=749H
Link Zone https://zoneoffroad.com/products/4-in-ifs-suspension-lift-kit-2019-2020-chevy-trail-boss-gmc-at4?variant=33675658297432
2019 AT4 - Ready Lift SST 2" level - OEM 275/65/18 Duratrac's
Zone Information Video
link:
Edited by Supercup
  • 3 years later...
you could compensate to reduce the angles from the 2" ready lift by dropping the diff 2 inches. this can be easily accomplished by removing the 4 bolts that hold the diff and using a longer bolt and poly urethane spacers. you don't have to reinvent the wheel here.
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
