So I received AMAZING assistance on my tailgate issue so I'm going to ask again for help getting this truck to stick around for more than a year.
Power steering (says dealer) pulley and or belt squeal.  Can I replace just the drive (serpentine) belt and skip the two stretch fit belts?
Where the hell is the power steering fluid (I have no manual, TB is TALL and hard to see into with the massive cover over the radiator fan.
Gurgle on interior (heater core I assume).  Is this 'normal' as I have heat but I'd love to NOT hear it everytime I start it.  Can the air be purged without major effort?
Heated seats, what on earth did GM do?  My 17 actually got warm quick, this thing takes MILES to even seem like its on.  The remote start just doesn't warm the truck like my 17 did, how did they manage to wreck something that worked so well just two years ago?
I'll take ANY input you've got.  I'm a serial truck addict but it's a money loss game for sure.  I just want one that I like enough to keep for once.  My wife suggested personalized plates, 5 in 5.  5 trucks (2 new even) in 5 years.  What's happened to build quality I ask.
I think I can help with a couple of these questions/issues.
First the steering is electric so there isn't any power steering fluid.
When using remote start, the heated seats don't heat well if unoccupied and the heated seats are cancelled when the ignition is turned on. So, you have to manually turn it up when you get in the truck (See page 64 of the Manual linked below).
Here's a copy of your manual: https://my.chevrolet.com/content/dam/gmownercenter/gmna/dynamic/manuals/2019/Chevrolet/silverado-1500ld/2019-chevrolet-silverado-1500-ld-2500-3500-owners-manual.pdf
JMHO
No expertise implied or expressed
I feel like an old senile idiot after learning they no longer are electric assist and went full electric.  I'd have hunted for hours looking for a fluid tank.
I installed my tuner today and looked at as much as i can actually see.  damn it's tight in there and SO MANY COVERS!  I have a trusted mechanic I think I'll just have replace all the belts and the idler arm, solve all the issues with one bill.
Now there has to be a way to purge the air from the coolant lines.  I almost regret getting a truck so new nobody has the same issues and a killer YouTube video on how to resolve them yet.
Pretty stupid how it will keep the rear defrost on when remote start and then turning key on yet it won't keep the seat heaters on.  bah.
I've found the 'auto' climate control to kind of suck.  Other than the seats and steering wheel on with remote start i find that in the wisconsin weather it's better to manage it all manually.  the truck really wants A/C and the rear defroster on all the time.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
