I installed the Auto Stop Eliminator brand on Monday.  Simple.  Maybe 30 minutes to install.  Good videos online on how to take the dash apart.  No issues so far.  I have PTSD every time I come to my first stop of the trip...  I think Oh No, I didn’t turn it off,  but then I remember,  I don’t have to anymore..
the stop/start feature on the diesel is awful.  When it would shut off, the whole truck would lurch because of the torque on the transmission.   So glad I installed it.
Ditto. A have the same and love it. I always give the analogy of it like a squeaky pantry door in your house. You just deal with it and you might get 'used' to it... but then you decide to spray the hinges with WD-40 and after that it's silent. And you're just like "holy cow, why did I not do that sooner??"
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
