Since 5.3 liters is just a couple of cubic inches short of 327 I decided to purchase some 327 emblems from Morris Designs and attach them to the bulge on the hood of my 2020 Silverado Custom.  As most Bowtie fans know, the 327 cubic inch V-8 has been historically important since the 1960's so I decided the 327 emblems would look nice on my truck.  The emblems are adhesive backed and nicely polished stainless steel so they blend well with the stock Custom emblems on the truck and bring back a little Chevrolet history.
  • Like 3
Gonna add this under the hood of my 6.6. Thought about replacing the 4x4 stickers with something similar. But may just go with deleting the badges.
Automobile makers have historically rounded up a cubic inch or two when publicizing displacement so there's nothing wrong with a slight "fudge."?
Quoted for truth. The old 396 was actually a 402.  The new coyote 5.0 is a 307.
On 1/7/2021 at 2:32 PM, Rob Mugs said:
Hmm.. I have a 378.  Pretty sure that'd look dumb ?
You would want to go with a 383 emblem.
That's a BIG stretch
Lol. That’s a big stretch. I have a 6.2L. Which is 378 cubic inches.  That’s the emblem I would want. Nothing less or more
I remember Furd lying to their customers for years stating the fox body V8s were 5.0L when  actually they were truly 4.9L.   And yes to me that’s lying and deceiving. Go with what is under the hood. Just my 2 cents
enjoy your day gentlemen
The older 302’s were actually a 4.9L, but probably went with 5.0L for marketing. Besides, Ford already had the 300 cid 4.9L I6 in their lineup for quite some time.
Old and new.  It's still a 302.  302/61=4.95L
That said, who would put 4.95 on their hood/fenders when only a 305 is a true 5.0?
Meh.. it's a 4.95.  So, rounding up .05, it is a 5 liter
Actually it was 4.942 for some that were earlier models of mustangs.
Here is a good article.  I found it funny
https://www.google.com/amp/s/dr1ven.wordpress.com/2012/11/01/ford-mustang-not-a-true-5-0-the-hoax-is-up/amp/
GM was closest to 5L with theirs at 4.998 with the c/k trucks and cars of the 80s and 90s.
The 396 was actually a 396 until 1970, then it became a 402.  They bored it .030 over.  The 396 engine already had a good following so they didn't want to change anything.  I've heard Chevrolet did it for emission reasons, apparently engines under 400 cu in had more stringent emissions, so the they made it a tad bigger.
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 665 Guests (See full list)
