I have read and listened to sound clips as much as I could and I decided to go for it. I have a 2021 TB with the 6.2 and I just couldn't stand how quiet it was.  I took it to the exhaust shop today and had them cut out the flapper valve and muffler and weld in a new piece of pipe. I kept the 2 resonators in place. I have to say I was pleasantly surprised and love the sound. well worth the $100. I spent.  But the problem is I can now hear clearly when it goes into deactivating cylinders....that I don't like at all.
can anyone tell me what's the fix to keep it in V8 mode all the time?
Run it in manual mode (L9 on the column shifter), and that will keep it in V8 mode. No DFM.
Thank you John. So the truck wont shift to 10th gear in this scenario correct?  I will try this but i really would like to just put the truck in drive and and still not have DFM working.
Yes, if you keep it in L9, the truck will shift through gears 1-9 and not go into DFM. So V8 mode all the time. Another option is to purchase the Pulsar LT from Range Technology for $449.95 and deactivate DFM using this device.Then you can keep it in D mode, and DFM will not be activated. Link for Pulsar LT below.
https://www.rangetechnology.com/products/pulsar_lt/parts/22451
I had a new muffler installed and removed the flappers. The tones(to me) aren't unbearable, just not ideal. I'm like you, though, trying to find an alternative way around.
I've debated having one or both flappers reinstalled, and maybe removing the resonators. I haven't yet found anyone that's done this setup for a reference, though.
Sent from my SM-G965U1 using Tapatalk
Had mine cut out about a month ago, sounds great, minor drone.. for the $75 I spent it was well worth it.  I have the 5.3 and get asked all the time if it's the 6.2.
Is this the exhaust leak type sound you are hearing?
I understand it sounds more like a helicopter.  I have an S&B intake (noisy) and my flapper removed.  I don't hear this
There is no exhaust leak sound.....It just sound like a 4 cylinder like a honda or suburu with an aftermarket pipe on it lol. Just sounds weird....Im going to do the pulsar lt as suggested above.
    B07
    B07
  • Who's Online   1 Member, 0 Anonymous, 729 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
